Take out inner door handle bezel-1 philips screw. Then remove 2 large screws under inner door handle. The lower light lens can then be removed exposing 2 small philips screws. Remove those and take out light assy and unplug. Use a screwdriver to pry gently on window-lock control switch assy. Remove and unplug. Then gently pry inner door panel off. The inner door handle and cables can be moves by sliding plastic assy back and out. Then you can remove the plastic rainliner exposing the door handle assy. 2 10mm bolts hold it in. Theres also to rods to remove by releasing clips and sliding rods out.
You will have to remove the door panel. To do this use a phillips screwdriver and remove the two screws under the inside door handle. Then lift and remove the section. Remove another screw from the interior lower left corner. Pry the window crank apart "if exists" then use a T20 torq bit to remove the screw in handle. Remove the panel by lifting and pulling at same time. With window in up position you can see inside the hole a rod going from the door handle to a bracket with a Yellow clip. Slide the clip to the open position and pull the rod out of the clip. From the outside of door under the handle there are two rivets. Use a punch and knock out the center of each rivet. Then use a 1/4" drill bit and drill out the rivet. A flat tip screwdriver will be used to knock off the rest of the rivet. You will need two flat head screws and lock nuts or to reinstall the handle. Lift out old handle with attached rod. Twist rod as you pull to remove it and install it into the new handle. Place the rod through the hole and look inside to be sure is will move to the location of the yellow clip.Install the screws from the outside and the nuts from the inside and tighten. From inside connect the rod to the yellow clip. Lift on the rod while closing the clip. Then test door handle. If it doesn't work properly the rod was not lifted or pulled outward enough. Redo that step until you get it right. Reinstall inner panel as removed.
Why does the interior knob or lever on my front entry
handleset sometimes cause the latch mechanism to jam and the exterior
thumb press to lock in place?If the front entry handleset is
newly installed, the latch mechanism may be binding. If the exterior
handleset is left sitting in the bottom of the bore hole through the
door, the rectangular spindle that extends through the latch may be
somewhat tilted and binding. This can be checked by loosening all
screws, slightly lifting the exterior handle, and then tightening the
screws before releasing the handle. This may make the spindle more level
with the latch and eliminate the binding. If this does not resolve the
problem, or the handleset has been installed for some time before the
problem occurs, the latch mechanism may be failing and need to be
replaced.
Remove front door handle bezel screw cover
Remove inside handle bezel screw
Lift upward on the rear of the front door inside handle bezel
Disconnect electrical connector
Remove handle screw cover Remove handle screw
Remove door trim panel upper screw
Remove door trim panel lower screw
Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel Disconnect mirror electrical connector
Remove 3 exterior mirror nuts and exterior mirror
Jaguar 2000-06 - Locks & Lock Systems Power Door Locks - Removal & Installation
Door Lock Switch Door Lock Diagnosis & Testing
Visually inspect the following:
Misaligned door(s), hood or luggage compartment lid
Door latches
Actuating rod
Exterior door handle
Interior door handle
Door lock cylinder
Cable
Luggage compartment lid exterior release switch
Fuse(s)
Wiring harness
Electrical connector
Door lock actuator
Remote transmitter batteries
Vehicle battery
Remote transmitter
Door lock switch
Front electronic module
If an obvious cause for an observed or reported concern is found,
correct the cause (if possible) before proceeding to the next step.
Door Lock Motor Coupe And Convertible
Turn ignition key to position II.
Motor door glass to fully raised position.
Turn ignition key to position O.
Disconnect the negative battery cable.
Remove door casing for access.
Remove door water shedder.
Position PVC secondary water shedder for access.
Slacken and remove the door glass rear runner lower securing screws.
Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
Slacken and remove the upper securing screw and move the runner away from the glass.
Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
Slacken and remove the three latch assembly securing screws and position latch for access.
Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
Release operating cable from door handle. Move inner door handle
to the locked position. Remove operating cable outer abutment from
support bracket. Disconnect cable inner from door inner handle.
Remove lock motor assembly from door.
To install, reverse removal procedure.
Fig. Removing door lock actuator
Sedan
Remove the door window glass
Detach the interior door handle.
Detach the actuator remote cable from the interior door handle.
Remove the interior door handle.
Detach the door window glass run.
Remove the exterior door handle retaining screws.
Remove the front door actuator retaining screws.
Reposition the front door actuator and exterior handle.
Remove the front door actuator and exterior handle.
Disconnect the front door actuator remote cable.
Detach the door lock cylinder connecting rod (1).
Detach the exterior door handle connecting rod (2).
Interior or exterior handle? Remove the door panel first. They make a special tool for removing the window crank, but usually you can get it off with a screwdriver. There is a little clip under the crank that needs to be removed first. Then remove the door handle itself, this has a screw in it. Then pull the panel off. With the window in the fully down position or the up position you should be able to get to the handle itself for the exterior. If it's an interior handle just remove that without taking the door handle off. This is all pretty self explanatory once you see it.
On the inside trim, you can remove screws that are by the door handle,
arm rest, under door and side of door and then gently pull back on the
panel as there will also be retaining clips attached and you don't want
to break them. You'll need to lift the door panel upwards in order to
get it off the window ledge. Then you'll need to manipulate the panel
and disconnect the door handle linkage from the door handle and
disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
SECTION 501-14: Handles, Locks, Latches and Entry Systems
2001 Escape Workshop Manual
REMOVAL AND INSTALLATION
Exterior Front Door Handle
Removal and Installation
Remove the front door trim panel. For additional information, refer to Section 501-05 .
Position the watershield aside.
NOTE: The tie strap does not need to be reinstalled. If equipped, remove the tie strap from the anti-theft guard.
Remove the screws and position the anti-theft guard aside.
Release the clip and disconnect the exterior door handle actuating rod.
Remove the anti-theft guard.
Remove the exterior door handle screw.
Remove the exterior handle actuating rod.
Remove the exterior door handle lock cylinder cover.
Peel back the watershield.
Remove the exterior door handle access hole grommet from the door.
Loosen the screw.
The screw must be fully disengaged from the door lock cylinder bezel although it is not necessary to fully remove the screw.
Remove the door lock cylinder bezel.
Slide the exterior door handle to release.
Remove the exterior door handle and gaskets.
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws
(Note: you do not need to back them all the way out). The handle will
then easily pull away from the door. With a 1/4" socket, tighten the
screws holding the upper and lower lugs on the door. Place the handle
back on and tighten the upper and lower set screws.
