Question about Home
I have a Selectronic Redring shower and it is keeps reverting back to temperature setting 1 (of 9). I can change the temperature suing the controls but it always goes straight back to 1. Although I have hot water in my flat there is none coming out of the shower. Any suggestions on how to fix this would be greatly appreciated.
brainyass
  • 242 Answers
SOURCE: Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Posted on Oct 23, 2008
  • 68 Answers
SOURCE: Only HOT water coming out of Redring Expressions 520 Power Shower
Hello philipknowle,
Regretfully we have cowboy plumbers on this side of the pond!! I Sent you a few links that should help. The last one is the installation manaul (12pages) The Middle one looks like a 60 page catalog. And the top one is the company website.
Please rate this response and best of wishes, Phil
www.redring.co.uk
http://www.protimbathrooms.ie/downloads/pdf/RedringBrochure.pdf Pages 21-23 looks like there is a 3 year guarantee on these units.
But this looks like the manual for this item
http://www.applied-energy.com/clientfiles/File/manuals/redring/Powerstream%20Instructions.pdf
Posted on Dec 28, 2008
Bati99
  • 88 Answers
SOURCE: Water not hot enough coming from my power shower
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
snap101
  • 117 Answers
SOURCE: The water coming out in the shower from a
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Posted on Jul 29, 2009
  • 67 Answers
SOURCE: Redring 3205 wont turn to cold - when control
Take a look at the .pdf document on their site. There will be adjustments within the unit that will assist you in adjusting the tempature. They advise that there could be seasonal adjustments that would need to be completed. I've assumed your model is the Activa 320S as I could not find a redring 3205. Good Luck.
http://www.applied-energy.com/clientfiles/File/manuals/redring/Active%20320S%20Instruction%20Booklet.pdf
Posted on Jul 30, 2010
Selectronic redring shower powering up , no water coming out and then turns off after approx 10 seconds
There are some troubleshooting actions mentioned on page 6 and 7 of the manual at this site
http://www.aroundtownflats.com/manuals/Shower%20Manuals/Redring/New%20Selectronic%20Instructions.pdf
The shower is designed to turn off within 30 secs if there is no water flowing through. The issue is why does water flow stop.
It can happen if shower is in overheat shutdown. Need to find if temperature setting is too high. There is a purge sequence to overcome this. See manual.
Apr 21, 2014 | Home
Redring expression 500 shower problem
your faucet have been wear out, you need to replace a new faucet
Sep 14, 2013 | Home
How to get lock off temp control off my shower redring selectronic extra
my redring keeps reverting to number one whatever i do help me please
Feb 04, 2013 | Home
Only cold water coming out of Redring digitemp shower
The temperature sensor in the unit is not functioning. It needs to be replaced!
Jan 14, 2013 | Home
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Jun 29, 2010 | Home
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
Apr 12, 2009 | Home
Hello philipknowle,
www.redring.co.uk
Dec 28, 2008 | Home
Home Logo
632 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
