Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Noisy Fans GE Artica Profile Side by Side
When either the freezer or fresh food fans kick on they sound like a jet taking off. How do I get to them to inspect for loose compomemts,
    Scholar:
  • 117 Answers
You will have to remove all shelves to access the problem areas. You will sometimes have to look carefully for the screws as they are camoflaged with paint, but i am sure they are there. Hope this helps
Posted on Jul 27, 2009
My ge profile psc25msta model's freezer is at 5 degrees and the fridge is 48. HELP!
5 def in freezer is good / look for frost on back for freezer . this would prevent air flow to fresh food side . laso both fans must be going . inside fan may be going to slow ( repl if so. ) clean coils under frig this will cause over run and poor refri. mm
Dec 07, 2009 | Washing Machines
My GE Profile fridge side isn't staying cold, but the freezer is. There is no thick frost built up in back of the freezer side so I know it isn't the defrost heater. Could it be dirty coils underneath the...
There are a couple of things that can cause this. Thermistors, mainboard, fan and damper.
Start with the cheapest.
1. Check Thermistors - Pull J1 and check connector pins 1,2,3 and 4 to pin 5. They should beapproximately 15Kohms. In your case, the freezer thermistors (pin 3 and4 ) should be higher than the fresh food (pins 1 and 2).
2. Fan and Damper - Fresh food fan should be on and damper from freezer to fresh food should be open. If not, check that fans spin by hand and damper doesn't look damaged
3. At this point it is most likely the motherboard.
http://www.fixyourboard.com/techzone/refrigerators/ge_fridge_warm/warmflow.html
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer (ge artica) temperature goes up to 40%, then cools dow
The main problem with the Artica/Profile is that they have a main control board and a thermostat board inside the fresh food compartment. I have a repair manual and will send you a copy if you want but we are going to have to look at the control boards for burn marks. Let me know if you need me. Thanks, Sea Breeze
Jul 15, 2009 | GE Profile Arctica Stainless Steel Top...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Freezer fan is making whirring noise
Generally the freezer or (evaporator) fan is behind the panel in the freezer and in most freezers Side by side or standard type have a series of screws or along the outer edges of the freezer panel...some (like in side by side have a freezer fan and a fresh food fan....but not many generally cold air from the freezer is introduced into the fresh food compartment by way of a vent or port hole that aloows free flow of cold air into the fresh food area (but I digress) anyway take out the (several) up to 10 screws that hold the panel in place...if you don't do it soon the fan will go out and then the freezer compartment will iIce over and the fridge will cease to cool...once you pull the panel you will see it ...take it out and take to Johnstone supply, Marcones, or WW graingers for a good price on parts. If you have them where you live.
I hope this helped....If so please rate me. thanks ...the Fang
Mar 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile Freezer not working
Main pcb failure but just check the wireing at the bottom of the freezer door as it can affect the control system
Feb 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Oct 29, 2006 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
