Hi, i have a hotpoint aquarius 6kg wma50, my
Hi, i have a hotpoint aquarius 6kg Powerstream wash system wma50, my problem is it is not draining water,the drum turns but also it does not spin now
Can anyone give me any ideas as to what can b wrong? Im thinkin i needa new pump, is that all i need?
All help appreciated,
Thanx
  • 1 more comment
  • Hunnimonster Jul 27, 2009
    Thanx for the reply, yes i have checked for blockages(well my sis did) There was a kink in the pipe,but i straightened it, also took out the white plastic bit with the ball in it,and cleaned it, still doesnt drain or spin
    Luckily a new pump isnt expensive, the laundrama will be makin a fair bit cash from me, lol till i get new pump
    how do i check power to the pump? dont have any tools, just normal screwdrivers etc, no other half(man) to ask to check for me
    Thanx
    thank u kjetiledv
    I will try wot u suggested, takin it to workshop, will let u know how i get on
  • 28 Answers
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Posted on Jul 27, 2009
  • kjetiledv Jul 27, 2009
    You can also check power to the pump, if you get power to pump then its settled. Or you can measure resisance on connectors on pump. If you have acsess to el tools.
    hmmm. if u dont have any tools that can measure voltage and ohm. than it wont be easy to check the pump. what u can do is dismount the pump from the machine and take it to your local workshop for appliances. then they can test the pump with power to see if it responds to power. if it rotates at the workshop and not on the machine, then you know the pump works. and than it must something with the electronics. we do this all the time at our workshop.
Problem with hotpoint aquarius wml520p 6kg 1200 spin washing machine doesent go into final spin
Have you checked the filter if fitted? Sometimes washing machines will not spin if they're not empty.
Jan 19, 2015 | Hotpoint Washing Machines
Hi, My hotpoint Aquarius WMA50 washing machine has just sparked and blown all the electricity off. I changed the fuse but this had no effect. All the dials are off and the machine will not come on. My wife...
if your machine is sparking I would say that you should unplug it and not use it --- call a service tech to check it out and see if it can be fixed.
( that unit is now a fire hazzard and a short in the system is obvious,, don't take any chances ).
c...
Dec 31, 2010 | Hotpoint Washing Machines
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Hotpoint WMA50 Front Load Washer
I have a hotpoint aquarius 6kg washing machine, i need to cancel a progeamme and drain the washing machine as their is a sleeve caught in the door and water is coming out but don't know how to please...
hiya
if the model starts with wm then you should set the timer knob just before a spin setting and it will empty out.
if the model starts with wma,few or wf then you will have to hold in the start button as this will cancel the current cycle and should start to drain.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Hotpoint Washing Machines
How do i remove a rear control knob on a hotpoint wma50s machine
to replace your timer dial take the lid of by unscrewing 2 screws at the back of the lid were your dial is look down a small oval shape opening u will see a screw undo it and the dial will come off m8
Feb 18, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
570 people viewed this question
Top Washing Machines Experts
