Question about Frigidaire Dishwashers
Every aspect of the dishwasher works except that it wont drain. After a short time on the drain cycle it turns itself off.
    Novelist:
  • 108 Answers
There could be something stuck in the pump. If you have a wet vac, you can try vacuuming out the water from the drain hose (it probably connects to the drain under the sink). If you try getting it back to the drain part of the cycle, and vacuuming out the end off the drain hose at the same time, you might be able to free the blockage...
If not, you will need to open the lower panel, and remove the pump so that you can open it and check inside. The pump might need to be replaced. If you don't have a wet vac, you will need to get as much water out of the dishwasher as possible from the inside, and then place a pan under the pump when removing it (there's not a lot of space, so be patient)
Posted on Jul 26, 2009
WON'T END WASH CYCLE/KEEPS ON RUNNUNG..IS THERE A CODE FOR THIS
If you cannot cancel the cycle then turn power off and back on.
Then try to program a short cycle from panel and see if it works.
I am assuming when you say that it keeps running you mean the water keeps churning and does not drain out.
If short cycle works ok then the dishwasher is not heating water to the correct temperature. Need to check thermostat or heater.
Apr 22, 2014 | Kenmore Dishwashers
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Dishwasher does not complete cycle
Does it have standing water after cycle? If so you can turn the knob until you hear the water kick into the sink. let it drain this way completely and stop the dishwasher before it starts to add more water. turn the dial or switch to its off location and the let the dishwasher cycle completely to ensure issue is solved. Your dish washer is "short cycling". This usually works 9 of 10 times
Oct 28, 2013 | Dishwashers
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Doesn't want to wash, doesn't want to drain.
Harry, a common drain problem on these GE dishwashers has to do with the piston nut assy. located under the filter grate in back. You can check it out here: http://www.repairclinic.com/0080.asp It's an easy fix, it just unscrews. The other issue sounds like a door switch problem. Remove the inner door and take a look at the door latch and switch for any broken parts. Catriver...post back.
Nov 26, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Cycles won't run
dc, sounds more like a shorted interface, a shorted keypad will act like this. There should be a tech sheet behind the toe panel on the bottom. It should have instructions on how to test the keypad and put the unit into the test cycle. Catriver..post back.
Nov 14, 2006 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwashers Logo
136 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
