Question about Microsoft Xbox 360 Console
E73 error message but if take out av cable no red light
  • jrfrank May 11, 2010
    After sniffing around further this error could actually be a close relation to the RROD (3 red lights) and as such would be a soldering issue between components such as the RAM/GPU/CPU. MS don't cover this under the RROD 3 year warranty (which is wrong!) but you might try MS support first and see if you can get it fixed with them (you might get someone who is nice :) )
  • 22 Answers
From what I hear E73 is to do with the Ethernet Chip and although you can fix this yourself, you're gonna have to be good at soldering and getting hold of the relevent 'tronics... I would send it back to MS and pay the 100 buckeroos, or buy a new arcade and switch drives?
Goodluck with it though!
Posted on Jul 26, 2009
2 Suggested Answers
  • 1093 Answers
SOURCE: E73 error and one red ring
1 red light is the display chip overheating and to fix it you need to stop the heat build up getting to the main chip to do this you need to send it in or use a good xbox 360 repair guide to fix it
Posted on Nov 17, 2009
E73 error on xbox
It's most likely overheated.
I would try putting a moist towel on top of the console and letting it sit overnight (while its off).
May 24, 2010 | Microsoft Xbox 360 Console
One red light and a e73 error code??
There are plenty of suggested fixes on the net, but whichever one u go for, make sure its NOT the Towel trick.... this will cause more damage in the long run, altho it does solve the immediate problem. If you are tech savvy, any fault, whether it be one, two or three red lights is quite easy to fix, but involves stripping the xbox down to the motherboard, then removing the to x clamps on the reverse of the board, and lifting off the 2 heatsinks from the processors, thoroughly clean all traces of old thermal compound from the heatsinks and processors and apply new paste. then using one of the many fix kits available on ebay re-attach the heatsinks as per instruction in the kit, plug in all cables but do not connect av cable to tv. turn on xbox until such time that 2 red lights come on. this means the unit is overheating, but it needs to do this to help with the bond of the new paste to the heatsinks. once the lights have come on, just unplug the power cable directly from the back of the xbox...do Not use the button. and allow to cool for approx 30 mins. re-assemble the xbox and hey presto u should be up and running. Any probs email me directly!!!
Mar 29, 2010 | Microsoft Xbox 360 Console
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
Feb 21, 2010 | Microsoft Xbox 360 Arcade
E73 Error
Error E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
This error is also caused by a cold solder joint under the Southbridge or the Ethernet chip.Can also be one of the solder joints that lead to the GPU.
check if you are getting any flashing red lights on your xbox 360 power up button, if you are not getting any flashing lights the probably you may try unplugging any Ethernet cable attached if you had tried connecting to Xbox Live and at that time you face this error, re-connect and check
If you still get this problem and you see a single flashing red light on your console, please send your console for repair to MS support if it is under warranty
Dec 24, 2009 | Microsoft Xbox 360 Console
One red light no image
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
If you try the first one and it doesnt work im sorry but you will have to contact MS or use a replacment plan if you have one.
Dec 06, 2009 | Microsoft Xbox 360 Console
E73 error and one red ring in the lower right quadrent. AV power cord when unhooked- no red light- when reattached red light reappears.
Nov 17, 2009 | Microsoft Xbox 360 Console
E73 error message but if av cabel is unplugged no red lights
Hi Mr .
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Accepte My Greetings
Oct 11, 2009 | Microsoft Xbox 360 Console
Has one red light on and e73 appears how do I fix
General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try unplugging and re-plugging all your console's cables.
Sep 28, 2009 | Microsoft Xbox 360 Console
What is this error code and how do we fix it E73?
This is an error code for an Ethernet issue. There are people who quick fix the problem on their own, but it will void your warranty, so I wouldn't recommend it. I'd contact Microsoft support and get it fixed through them. You may have the option of getting another warranty after you get it fixed.
Jul 26, 2009 | Video Game Consoles & Games
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
375 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
