Rooms farture from airhandler are 3 to 4 degrees warmer and rooms close to airhanler are 2 or 3 degrees cooler blower motor set on highest speed unit runs too long 18 min on 10 min off 100 degree outside temp tstat set at 75 degrees
  • 339 Answers
Here are a few things to try in order:
1. If you have access to the ductwork and there are internal dampers on the branch ducts going to the individual registers, make sure the far ones are fully open and slightly close down the ones that are close to the air handler. You may have to experiment a bit to get an airflow you're happy with.
2. If you don't have damper adjustments, try to restrict the airflow at the individual registers near to the air handler to reduce air flow to these and force more air to the far ones. Some registers have an adjustment for this; if not you'll have to make something like a cardboard insert to block part of the air flow. The downside is tha that the restricted registers might get a bit loud.
3, A last ditch option is to install booster fan(s) for the more remote ducts. These can be internal or external like this: http://www.smarthome.com/3010/Heating-Air-Conditioning-Booster-Fan/p.aspx
A few other things that might help marginally include adding insulation and/or moving your thermostat.
Hope this helps. FYI, usually when you have an issue with a system out of balance like this it indicates either a badly designed/installed system or a case where a building was added on to and the original a/c was extended to cover the new area.
Hope you cool off soon.
Posted on Jul 26, 2009
A/c switch not working only on highest setting
Neither probably.
There should be a high speed relay that powers the blower on high only.
Jul 27, 2012 | 1996 Dodge Ram 1500 Club Cab
The blower motor for the air conditioning doesn't come on. The compressor comes on. I ohmed the blower motor and it was good. I jumped the blower motor and it turned freely. With the control set 1 2 3...
> With the control set 1 2 3 4 it does blow any air,
? does NOT?
A common problem with this control is the failure of a stepped resistor which causes only the highest speed to still function since this bypasses the resistor.
Tracing the leads from the fan speed switch may help locate it.
Sep 04, 2011 | 1997 Honda Accord
2005 Jeep Grand Cherokee. Htr/AC fan switch only functions @ highest speed. At lower speed settings I can hear doors opening and closing---but not air.
replace the blower motor resistor. It controls the fan speeds. It defaults to high speed only when it fails.
How to replace the blower motor resistor block: Caution: Stay clear of the blower motor and resistor block (Hot). Do not operate the blower motor with the resistor block removed. 1. Disconnect and isolate the battery negative cable.
2. Remove the glove box from the instrument panel.
3. Pull out the lock on the blower motor resistor wire harness connector to unlock the connector latch.
4. Depress the latch on the blower motor resistor wire harness connector and disconnect the connector from the resistor.
5. Remove the two screws that secure the blower motor resistor block to the HVAC housing.
6. Remove the resistor block from the HVAC housing. Installation:
1. Position the blower motor resistor block into the HVAC housing.
2. Install the two screws that secure the resistor block to the HVAC housing. Tighten the screws to 2.2 Nm (20 in. lbs.)
3. Connect the wire harness connector to the resistor block.
4. Push in the lock on the blower motor resistor wire harness connecgtor to lock the connector latch.
5. Install the glove box.
6. Reconnect the battery negative cable.
7. Have a nice day!
Oct 11, 2010 | Jeep Cherokee Cars & Trucks
The blower for the ac/heat only works on the highest setting. The 1,2,&3 settings don't work.
Sounds like the blower motor resister is bad, it regulates the speeds of the blower motor, it should be located somewear around the blower motor, 2 screws hold it in the heater box and it has a electrical plug to it.
Sep 30, 2009 | 2002 Jeep Liberty
AC only works on settings 3 & 5
souns like a bad blower resistor.the resistor controls the different speeds.sometimes every speed except the highest will stop working.the blower resistor is almost always near the blower motor.
Sep 03, 2009 | 2004 Chevrolet TrailBlazer
2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Aug 15, 2009 | 2002 Honda Odyssey
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
Heater blowere shuts off at the highest setting
heater blower motor risister most likely cause. should be under dash near heater motor.
Jan 16, 2009 | 1997 Jeep Grand Cherokee
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
