Question about InFocus ScreenPlay 4805 Multimedia Projector
4805 i have a 1 ft wide shadow going down the length of the screen on the right side, what can this be and is it fixable?
  • 1 more comment
  • Anonymous Nov 25, 2007
    I have same problem. Took out bulb and lenses blew everything out. Still have shadow. I contacted infocus, waiting for reply.
  • tocarpen Dec 10, 2007
    thanks. I am probably going to get it replaced.
  • Anonymous Dec 18, 2007
    I have the same problem, only the shadow runs from top to bottom on the left side of the screen. I have had the projector for about 4 years and I thought it must be time to replace the bulb. It did not help and now the picture is not as bright as it use to be also. Bulb replaced 12/17/07 I would appreciate any advice.
    thank you
I took the projector ap part and found that the square box / glass pris-sim had come ap-part. I also cleaned the color wheel. The picture is back to normal. I used 60 sec epoxy to put the square box back together.
Posted on Dec 18, 2007
Is your projector ceiling mounted? This is a common problem with these projectors, I am assuming that this projector is ceiling mounted because the shadow would be on the left if it is the right way up. This is caused by the light tunnel (a sort of hollow box made of mirrors) collapsing. It will have to be replaced but can also be glued (araldite epoxy or similar NOT SUPER GLUE) back together if the mirrors are still in good condition but requires a lot of patience. Best left to someone who has done this before as the colour wheel has to be removed and this is very delicate.
Posted on Dec 09, 2007
  • 3 Answers
Do you have the projector inside a hush box? If so, it could be too far back in the box. Readjust and see if that removes your shadow.
You may have a haze on your lenses. Have you tried cleaning your color wheel and associated lenses? This procedure is for the skilled since you must disassemble your projector. Keep in mind that the color wheel is VERY, VERY fragile. Use a lens cleaning agent or 91% isopropyl alcohol and q-tips. The agent must not leave a haze. Have plenty of time and patience since this may take you about an hour just to clean the color wheel. Did I mention that the color wheel is VERY fragile…
This link may also be helpful. See section 5.10.
I hope this helps,
Posted on Nov 28, 2007
2 Suggested Answers
SOURCE: shadow on right side of screen
Shadows on the left or right (if the projector is ceiling mounted) of the projected image area has nothing to do with the DMD it is the light tunnel tha is at fault. See other posts about this problem.
Posted on Dec 31, 2007
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
A shadow on the right side of the screen from top to bottom
Something inside the unit is out of alignment in the light path
Apr 23, 2010 | InFocus ScreenPlay 4805 Multimedia...
Slight shadow on right side of screen
this is image banding. the light tunnel needs to be adjusted, or replaced if it is collasped.
Apr 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
It has a shadow on half the screen
the light tunnel has collapsed. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good.
Jan 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have shadowing on the edges when in wide-screen. When in normal screen the image is fine. How do I get rid of the shadow? Also, is there a way to clean the mirror inside the unit?
the only way to properly and safely clean anything inside is with canned air. as for the shadow, replace the light tunnel. you can get the part from an infocus service center and replace it yourself, or send it in for repair. either way, try av solutions in ny. they're really good.
Dec 25, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a dark shadow down one side of the screen
replace light tunnel = use service manual for procedure....T.
Dec 13, 2008 | Samsung HLP6163W 61" Rear Projection...
4805 shadow
I had the same problem just 99 hours after changing the lamp for the first time. The problem you describe is most likely the light tunnel that is cracked. I wasn't able to buy a new one on my own, I had to turn it in for repair. The light tunnel is only a couple of mirrors that the light travels between.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Shadow on right side of screen
check the connector of DMD module. Service all projector and reinstall.
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
InFocus ScreenPlay 4805 Multimedia Projector Logo
232 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
