Question about Hayward Aquabug Above Ground Pool Cleaner Hay500
My Aqua Critter seems to get clogged up pretty quickly. We just opened a pool that had been closed for a year. There are a lot of leaves in it. Is that why it cloggs so quickly?
    Scholar:
  • 173 Answers
It most certainly is.
The simplest solution, is to sort of half the work for it, by collecting as much leaf litter, as you can with a net, before sending in the critter.
Also, a cover, will drastically minimize the amount of litter entering the water.
Have fun fishing:)
Posted on Jul 26, 2009
Stila Aqua Glow Perfecting Primer india ?
Create the perfect canvas for your makeup application with this refreshing primer stick. Aqua Glow Perfecting Primer is packed with cooling ingredients that leave skin looking silky, even, and pore-perfected while hydrating and soothing the skin.
STILA COSMETICS INDIA
Jul 14, 2016 | Aqua Pool & Spa
How do I set the pill in the pool?Large hole up or down
read for how many gallons it will tell you how many to open
Sep 18, 2014 | Pool & Spa
Have a 2 hp 2 speed Pentair whisperflow pool pump, it seems to only operate in low speed.. is about 5 years old..checked for obstruction at impeller but seems fine..any suggestions much appreciated..
check for power on high with a meter, or bring it to your local pool pump motor repair guy with free testing. TAKE NOTE on where the wires are hooked up !! they must go back the way they came off !!!
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
I am looking for a Flo-Master XP2 by Aqua Flo. Modal 06630397-2. How much would it be?
A quick google search brings up a number of online sites between $340, and $430
Sep 22, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Aug 18, 2010 | Aqua Vac Tiger Shark
My aqua critter doesn't crawl along the pool floor when hooked up, what could be the problem?
There are several things to check when these pool cleaners are not moving forward properly or with adequate speed. First. check to make sure that you have enough water flow through the cleaner. Clean your leaf canister, hair and lint pot, and your filter system. If they are clogged/dirty, they can cause improper water flow. You will also want to check for a blockage in the cleaners throat and remove it if necessary. Finally, check to make sure that your wings and shoes are not worn. If they are worn, replace them and it should correct the problem.
Aug 05, 2010 | Hayward Aquabug Above Ground Pool Cleaner...
Vaccuuming
Do you have a 'Earth' dirt filter system?
If yes - these system clog up very quickly when 'vac'ing - if can - when pool is v-dirty - 'vac' on waste setting (will loose lots of water but)
Also - get yourself some filter socks for the skimmer box filter - this will help heaps!
When can / if can - repalce filter system with a sand filter system - much easyer to use - easyer to vac pool - easyer to add chemicals - just easyer.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
Aqua critter
Remove the center inlet port and check for some sort of blockage in the intake jamming the drive paddle.
Jun 14, 2009 | Hayward Aquabug Above Ground Pool Cleaner...
Hayward Aquabug Above Ground Pool Cleaner Hay500 Logo
315 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
