Question about NetGear MR814 Wireless Router
HN9000 DSL and RangeMax Wireless not connecting wireless laptop
I just got hughesnet's HN9000 and am trying to install the RangeMax Dual Band Wireless-N Router. I can still use my desktop fine but my laptop will not stay connected. It finds the wifi network and says it is connected for a second then disconnects. I have 100% strength...
  • 374 Answers
Connect the modem directly to the Computer first and try n go online if the network is not disconnecting frequently and if everything works fine then this is the no. for the
  • Netgear Tech Support 1800-211-2069
  • Netgear Tech Support 1-888-638-4327
It's a toll free number call them and they will guide you step by step in a proper way.
If you are not able to stay online with the modem directly connected to the PC then call the hughesnet customer care 866-347-3292.
Good luck.
Posted on Mar 15, 2010
  • 111 Answers
Uninstall then reinstall wireless card drivers then reconnect.
Posted on Jul 26, 2009
I have 2 problems:- The first is it seems that if I've one laptop logged in via wireless I cannot connect a second wirelessly! The second is I have a 'n' capable laptop but it will not connect to the...
What you can at first check your router setting if there is a security set only for 1 computer and a pass key. If there is any, configure it to make the second laptop connect to the router.
Mar 15, 2011 | NetGear DGND3300 RANGEMAX DUAL BAND...
HN9000 won't pass remote services
On the Router check if you have UPnP enabled, if yes then Disabel it that should fix the NAT issue and then you need to open the port number 1723,3389. Once these ports are opened then you will be able to access it on the VPN and Remote Desktop Provided you have a WAN IP Address from your ISP. also check the Firmware of the router if its updated or not.
Mar 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Trying to install linksys wireless router to
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 04, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I need to connect linksys router to hughesnet hn9000 modem
First make sure you are able to go online when your Hughes-net box is connected directly to the Computer.
Then go to this Link and you'll get all the information you need Setting Up Wireless connection
Note this number Linksys Tech Support 1800-326-7114. It'll come in handy.
Rate if you find it useful.
Good luck.
Feb 12, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Laptop drops signal but other doesnt
This issue generally occurs due to the outdated Wireless Driver.
Check for the Updated Wireless Driver for your Computer (in which signal is dropping) and install in the Computer to resolve the issue.
If the Updated Wireless Driver is not available then un-install the Wireless Driver and install it again to resolve the issue.
Good Luck!!!!!!!
Nov 03, 2009 | NetGear RangeMax Dual-Band Wireless-N...
I attempted to use my Netgear RangeMax Dual Band Wireless-N USB adapter (WNDA3100) on an HP Pavilion ze4900 laptop. In the installation process, the laptop never recognized that new hardware had been...
To isolate the issue. please install the adapter on another computer. If the other computer does not detect the adapter then that means the adapter is faulty.
Let me know the results.
Oct 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear MR814 Wireless Router Logo
361 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
