Question about Garden
Two problems please: craftsman 2150psi briggs and stratton engine washer, will not start when hot. and secondly, i was washing with regular pressure, then noticed a pressure drop at the nozzle, then the unit shut down. no water leaks at the manifold. water supply was strong. any ideas?
    Sergeant:
  • 384 Answers
Nozzle dirty, clean out with small diameter wire.
Posted on Jul 27, 2009
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Engine runs for a few minutes then stalls...
It sounds like vapor lock or other lack of fuel. Premium gas will cause detonation and "may" have something to do with it. Drain the fuel the best you can and add regular fuel, after a couple minutes the engine should be burning mixed fuel and if the problem goes away you have fixed it, if not you obviously have other issues.
Jun 19, 2010 | Craftsman 2500 PSI Briggs Stratton...
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
