Question about GE JKP15 Electric Single Oven
ERROR MESSAGE 5F
THE OVEN NO LONGER WORKS,, THE ERROR MESSAGE IS 5F MODEL # JKP15AOW1AA WHAT IS THE PROBLEM ?ADVISE THANK YOU
  • 6,784 Answers
This fault concerns the relay drive circuit. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Posted on Jul 26, 2009
Error F68, beeping continuously
Hello Rasheda, this is Z. Thank you for your post!
If you are getting an error code F68 on your Electrolux oven, it typically means that your appliance may be experiencing an issue with the incoming line voltage. One of the best ways to determine if this is a false error code is to rest the power to your oven by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech since this is not a simple DIY job. He/she would need to determine whether the problem rests with the power supply voltage or EOC (Electronic Oven Control). I hope this helps explain the error code you are receiving.
Apr 10, 2014 | Electrolux Ovens
Model RBD245PDT12 has message error E6 and F2
This is a common failure of the control board. It is often accompanied by a intermittently blank display. The board is no-longer-available but we can rebuild it for you at www.fixyourboard.com.
Control board part number: 8302967
Apr 21, 2011 | Whirlpool RBD245PDS Electric Double Oven
Hi - I have a whirlpool gold series electric double oven. The error message is E1 F2. Anyone know how to fix this?
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Jan 05, 2011 | Whirlpool RBD305PD Electric Double Oven
What is an f1 alarm code on a kenmore wall oven model 9114012191
problem has been fixed. thank-you for your help.
Nov 10, 2009 | Ovens
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Couldn't open door after using Clean Cycle Function
hi thanks for the question there should be a solenoid at the back where the lock rod comes out check there thanks the appliance doc
Sep 23, 2008 | Thermador C301U Electric Single Oven
GE JKP15 Electric Single Oven Logo
323 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
