Lands Phones Logo
A
Anonymous Posted on Jul 04, 2017
Why is my phone giving me a message: No sim inserted or why is my Samsung S5 2017 model requesting that I insert a pin to unlock my sim card if I have not switched off my phone.
This happens intermittently. My handset is only 6 months old and in good condition, have not been dropped and is well protected and looked after. The message appears spontaneously, without me having touched the handset or switched if off.
Pcm2048
Level 3:
  • Master 754 Answers
  • Posted on Jul 04, 2017
Pcm2048
Master
Level 3:
Answers
754
Questions
0
Helped
201299
Points
2186
Have you tired removing the sim card, giving the contacts a clean and putting it back in. Sometimes they will be dirty and make intermittent contact. If you want to clean the contacts, remove the sim and CAREFULLY clean the contacts with alcohol or methylated spirits. See if that works.
Insert sim card
If your Samsung SGH-E490 phone displays an error message saying "Insert Sim card" after inserting a Sim card then your phone is probably network locked.
To unlock it,visit TheUnlockArena.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then,you can use freely any GSM network sim.
3answers
My proble is i insert sim in mobile massage show please insert sim. my mobile model is m200 samsung
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
You `can contact a skill personnel for help.
Have a nice day.
2answers
Need unlock code for sony ericsson z550a for a tmobile SIM
Hi, If you get error message as PIN blocked. Unlock?" You have entered the wrong PIN code too many times. You need to unlock your phone using the PUK (PIN Unlocking Key) code. Your PUK code is provided by your network operator. If you get error message as Insert correct SIM" You have inserted a SIM card that is not supported. Insert correct SIM card, or contact your Service Provider for a SIM unlock code. If you get error message as Phone locked" or "Enter PIN" Your phone is locked and you need to unlock it with your personal PIN. The default PIN is '0000', but you or your network operator may have changed it. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Unlock a sony ericsson w302 on tesco
Unlock code for sony W 580i
16helpful
3answers
Samsung e250 simlock code to unlock
1.insert this code *7465625*28782# without sim card.
2.the phone will show you message of protected activated,click o.k.
3.again insert the same code without sim card.
4.now put in your sim card.
5.when you put in different sim card(network),phone will ask for code,insert all the 0's phone will work on any network
Hope this works for u
3answers
Unlock code
SIM Cards and Unlocking your Phone What is a SIM?
Subscriber Identity Module (SIM): A smart card containing the telephone number of the customer, encoded network identification details such as: Call Forwarding, Caller ID, etc., the PIN, and other user data such as the phone book. T-Mobile customers can move their SIM card from any T-Mobile branded phone to any other T-Mobile branded phone without the need to contact Customer Service to activate the new phone. Your rate plan and phone number will follow your SIM to the new phone.
SIM Error Messages:
  • Invalid SIM: This error means that the SIM you have inserted into your phone is either inactive or is not compatible with our service. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
  • Insert SIM: Your SIM is either not inserted in your phone or is inserted improperly. Please remove and re-insert your SIM card. If you continue to receive this error message, your SIM card or phone may be defective. You may take your phone and SIM to a T-Mobile retail store for further assistance and a free SIM card replacement if necessary. Locate a T-Mobile retail store near you.
  • Unregistered SIM: This error may occur if your SIM card is not fully activated or if the SIM card registered to your account is different than the SIM you have in your phone. For assistance with this issue, please contact Customer Service.
  • SIM Not Ready: This error occurs when you have just powered your phone and is due to the phone not being fully initialized. Please wait a few moments before accessing your phonebook or placing a call.
  • OTA OK: This message is displayed when your phone receives a network update, phonebook download, or an Over-The-Air t-zones or Picture Messaging configuration. NOTE: These messages are free of charge and will not be billed to your account or pulled from any text message bucket.
  • Enter PUK: These errors can occur if you have entered your SIM PIN three times incorrectly. If you receive this error message, please contact Customer Service for a PIN Unblocking Key (PUK) to restore access to your phone.
  • Check card, Card Blocked See Supplier, Blocked, SIM Blocked, or Contact Card/Service Provider: These errors may occur if you have entered your PUK ten times incorrectly. If these errors display your SIM is unusable and you will need to purchase a new SIM card. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
SIM PIN:
A SIM PIN can be used to prevent access to your phone. When enabled, your phone will prompt you for the SIM PIN when the phone is powered on. Entering the wrong PIN will prevent you from making or receiving calls. SIM PINs are different from a Security Code that your phone may use to secure other phone functions. Please check your phone’s manual for further security details.
T-Mobile SIM PIN numbers are set to default values before purchase. If you change your SIM PIN, it is recommended that you keep record of the new PIN in a safe location. T-Mobile cannot retrieve a lost or forgotten SIM PINs.
  • SIM PIN1: 1234
  • SIM PIN2: 5678 (Only available on select phones)
SIM Unlock:
T-Mobile branded phones operating on the T-Mobile network may only use T-Mobile SIM cards. To use a T-Mobile branded phone on another wireless carrier's network with a non-T-Mobile SIM card, you must first request a "SIM Unlock" code from T-Mobile. Conversely, if you have a phone from another North American wireless carrier, you may need to request a "SIM Unlock" code from that carrier before being able to use a T-Mobile SIM card on the T-Mobile network.
SIM Unlock Requests:
T-Mobile customers must meet the following eligibility requirements before contacting Customer Service to request your SIM Unlock code.
The following restrictions apply to all account types:
  • T-Mobile can provide SIM Unlock Codes only for handsets sold by T-Mobile USA, with the exception of Danger Sidekick devices. T-Mobile can obtain SIM Unlock Codes for companies acquired by t-Mobile USA (VoiceStream, Aerial, Omnipoint, SOL, Digiph, PCS One, and Powertel).
  • SIM Unlock Codes will only be provided after your account has been active for 90 days. Only one unlock code may be provided per customer every 90 days.
  • No SIM Unlock Codes will be provided within the 14-Day Buyer's Remorse period. Customers who purchase phones in CA California or via Amazon.com are granted a 30-Day Buyer's Remorse Period.
  • SIM Unlock Codes are not always available from the Manufacturer. However, T-Mobile will make a dedicated effort to obtain the SIM Unlock code. Note: Other restrictions may apply depending on account type.
Goodluck
3answers
Unlock
i want use it in egypt
Problem regarding mobile sim card chang
Your phone is asking for a code because it is locked to only work with one phone company. If your new sim is from a different company, you can request the unlock code from your old company, they may or may not give it to you (tmobile usually does, ATT/Cingular usually doesn't). The other option is to use a unlocking service, you can find plenty on ebay. If you didn't change phone companies, your new sim card is most likely bad, have your phone company send you another one.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
