Question about Metra Gm S 10 Firebird Camaro 91 82
Carb promblems I have gas comeing out of the tubes above my holly carb. what can i do?
    Scholar:
  • 173 Answers
You will probably find that the feul pipes are fatigued, and more than likely, split.
They probably need replacing.
Good luck with that.
Posted on Jul 26, 2009
Problems with exhaust tube comeing from carburetor is leaking gas four wheeler dies with I open the throttle wide open
There is no "exhaust tube" on a carb. if you mean the overflow tube at the very bottom of the carb, then you need to disassemble the carb and clean here(and everywhere else too while you've got it apart) this will most likely fix all of your problems.
Feb 13, 2015 | GAS Motorcycles
I have 700 holly double pumper that is shoot fuel out of 1 of 2 tubes that stick up from the top of the carb that seem to b hallow
This is the accelerator pump shots escaping from their normal path due to some parts missing or installed wrong. Carb overhaul should find the issue, but probably boosters loose or something similar.
Dec 29, 2014 | Cars & Trucks
Where is the main fuel line intake on my holly 4 barrel carb?
If it has a hose hookup you attach it there with a clamp or if you do not have the proper fitting or fuel line end you will have to get the proper parts.
Dec 14, 2014 | Cars & Trucks
Hello i have a 1979 dodge brougham motor home 318 engine 4 barreal carb..raw gas was pouring out of smog caninster..took locl pliears and crimp gas line comeing from carb..what could be promblem...
Probably the float stuck open. Time to rebuild the carb. Motor homes set to long to many times. gas has a residue that builds up and makes things stick and clogs up small holes.
Sep 03, 2011 | Dodge 400 Cars & Trucks
Holly 4 barrel the 4 barrel will kick in untill the vechal is got a little speed up then it kick up hard i need it from the start
Sounds like you plunger is not working rt. may need a carb kit. good luck.Could try some carb spray in your carb.. or another possability is you got some bad gas somewhere, .
Mar 26, 2011 | 1982 Ford F 150
Got a 85 ford f150 has a 302 holly carb. was running fine ran low on gas and now cuts out wont back out of drive way idles fine but hit the gas and it stalls
strip and clean out the carb,or quick fix ,rev engine with air filter off and then hold hand over intake this may or may not not cure it .because when hand is held over carb and stops air the suction will draw any muck through the jets
Jan 03, 2010 | 1985 Ford F150
I have 327 with two holly 650s on it I am getting a dead spot when I push the gas pedal down its about half thottle it kinda dies then if I give it another push on the gas it will go I changed the gas...
It could be a acceleration pump problem, or it could be that there are larger jets in the back carb. witch could make it hesatate when the secound carb. is starting to come in. Also holleys are a tempermental carb. and climent has a lot to do with there performance. You also might want to chk. the flote level, to low can cause it to hesatate.
May 07, 2009 | 1986 Chevrolet Camaro
Carberator problem - holly carb on chevy 350 motor
You are correct, there is a float inside a holley 4 barrel fuel bowl.
Is the electric fuel pump regulated? If the fuel pressure is above 8 lbs, you could run into this issue or the float / needle / seat could have a problem or miss adjusted.
By the way, a 2007 GMC is not carbureted so I assume this is not the vehicle or it has been modified.
Good luck.
Regards,
Apr 27, 2009 | 2007 GMC Sierra 1500
Metra Gm S 10 Firebird Camaro 91 82 Logo
55 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
