Question about Hayward 1.5 Hp Northstar High Performance Pump
My pump pressure is low i close valve to pool pump pressures up then i opn it and get better suction and discharge to pool but then it quits pumping
  • Book Book May 11, 2010
    Can you give me more of an idea of your setup? I need to know where is the pump located relative to the base of the pool? What size pump are you using (pump head pressure/ horsepower) That information should be on the name plate of the pump. What size hoses do you have and how long are the hoses?
    Also, I assume you are trying to fill pool? Correct?
    Forgive me for asking so many questions, but I hate to steer people in the wrong direction.
  • 128 Answers
You have a suction leak or a clogged impeller
Posted on Aug 30, 2009
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
No suction for pool vac
If you are not getting any suction to the vacuum, but the pump is working fine the rest of the time, start by checking all of your connections that conncets the cleaner to the filter and pump. Make sure there are no cracks, lose hoses, etc. Then, check for the following common problems with your pump that might cause low pressure in pool pumps:
1) Pump not primed
2) Leakage of air into suction system
3) Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5) Plugged basket in skimmer or hair in lint strainer
6) Dirty filter.
Sep 09, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
When the pool pump is working water flows freely with good pressure but there are air bubbles. when the barracuda is connected the pump looses the pressure, the g3 moves sporadically and the water flow is...
If you are seeing air bubbles in the leaf pot on the pump, you have an air leak on the suction side somewhere between the pump and the pool. Check the pump lid o-ring for any dirt, leaves, etc. Make sure the O-ring on the lid is not cracked, dry (lubrication like Aladdin's Magic Lube) or compressed or flattened. Also check your union or threaded connections to the pump suction (end) to insure they are tight and sealed. If this is an in-ground pool, and equipped with valves to control skimmers and bottom suction, close each valve separately to see if the air bubbles diminish. If the bubbles diminish when the valve is closed, then the air leak is in the closed section from that valve back to the pump. If the air leak increases, the air leak is in the still open line. Since the Kreepy crawly works on suction and increases the vacuum, the air leak will become more apparent, resulting in a loss of pump efficiency and flow, resulting in lost performance on the cleaner. If so equipped, close off the bottom drain valve and increase the suction on the vac line. I can provide further details as needed, but will need more information from you regarding actual equipment layout.
Sep 07, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My jaccuzi message pump pressure is low
It could be any one of the following problems. Try these troubleshooting steps for Jaccuzi pool pumps.
1)Pump not primed. Prime pump.
3)Impeller clogged
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
Aug 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
I loose discharge water flow after about 5 minutes of running perfectly. The pump has no air bubble and is trying to push water thru filtration system ( if I open the backwash valve I have very good flow...
If you have a pressure gage it would help .. if the pressure is high then there is probably an obstruction in the return pipe to the pool .. if the pressure is low then there is most likely a restriction in the supply or suction side of the pump .. this would seem more likely to me from your description, there may be something obstructing the flow into the pump, a clog, a collapse hose from the suction, some flap of pool liner .. something like that ..
Please Vote !
Jun 01, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Pump won't **** when attach the hose
Its very possible that it is not a problem with the pool pump, but a problem with the conncetion to the vacuum hose. If you are losing pressure only when you vacuum, make sure that your connection is secure and you have no holes, cracks, etc. in your line. If you think that there are definate pool pump problems, check for the following problems.
1) Clogged or restricted strainer or suction line
2) Plugged or restricted discharge line of filter (high
discharge gauge reading).
3) Air leak in suction (bubbles issuing from return fittings).
4) Pump operating underspeed (low voltage).
5) Plugged or restricted impeller.
May 31, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pool doesn't have pressure. Checked pump no blockage. Had the pool guy put air through the lines and no clog. Filter has zeobrite sand, but it's green? Pool company said it shouldn't be green. We are going...
Hi my name is Juan and I was a pool tech in california now located in georgia and let me try solve this if your filter is dirty it created a high pressure in your filter gauge with poor suction to check this bypass the filter and see if suction increase sometimes your gauge is bad and is not showing the true reading but if is good and pressure is to low then is so clear you have a suction leak try to replace the pump lid O ring and if you have spa check the intake valve where you select pool or spa if you don't have spa then the air leak is in the pipe connected to the pump suction side believe me this is a common problem
Jun 15, 2009 | Pool & Spa
My pump is running however it's pressure is less than 10 psi and the heater on the pool will not run.
With the Jacuzzi Magnum pool pumps, low pressure is going to likely be cause by one of the issues below. Try these troubleshooting tips.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My pool pump pumps water, return is low pressure
fix any air leaks on suction side of pump. Check valve positions.
Clean filters...may need to replace cartridges in cartridge filter, or take out D.E. grid assembly and clean it on a D.E. filter, or change sand in a sand filter...
Mar 26, 2009 | Pool & Spa
Hayward 1.5 Hp Northstar High Performance Pump Logo
201 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
