Question about GE JGRP17 Gas Single Oven
F7 error code - GE JGRP17 Gas Single Oven
  • 7 more comments
  • wlindsay Mar 02, 2008
    The in the wall ge oven is reading f7 code, but the digital clock is still working, but no other buttons are working, the f7 keeps making a alarming sound. Was working great until I sprayed the top vent area. Please help asap
  • ybuy07 Mar 03, 2008
    We have the same problem, oven is in off position, clock is working but other keys are not workin?, Any solutions to this problem. Please post it ASAP.
    Thank you.
  • ladinde Apr 26, 2008
    I have the same problem with the GE JGRP17. After using my oven last night, it started beeping and flashing the F7 error code. I tried turning off the power, but that didn't work. The oven is now disconnected from the power supply because the beeping will not stop.
    How do you clean "the electrical connections to the control board"? Has this worked for anyone? Any other possible solutions?
  • greg2277 Jun 07, 2008
    I have had this error on my oven (electric) but I think your touch panel is similar. Had same F7 error 3 times and figured lasting fix.
    Remove the panel, there is a ribbon attached to the board, unclip it. Clean the contacts lightly.
    Reinstalling at this point is tempory fix.
    For long lasting results, get a tube of dielectric grease at an auto supply store like Kragan's. Using a tooth pick, apply a light bit on each contact on the ribbon, be neat applying the dielectric so not to bridge(short) the contacts. Renstall the ribbon. Been 4 years since last cleaning, and no problem with oven.
  • lespinosa00 Jul 24, 2008
    What is the easiest way to remove the control panel
  • Anonymous Jul 30, 2008
    THANK YOU... I had the same issue of F7. Took apart and put dieelectric silicone on ribbon connection and it has not actted up for a week now. Was doing it once a day. Thank you for your help
  • wadh Aug 22, 2008
    need a permanent fix to the F7 problem, suggestions?
  • sgcole Sep 22, 2008
    My oven was off and all of a sudden it came up with the default F7-E6, the first few times I was able to clear it off but now it is on the control pad and nothing on the control pad will work. I tried disconnecting the power but this did not change anything. I've read about the fix of the ribbon, my problem is how do I get to the control pad ribbon.
  • Anonymous Jan 27, 2009
    F7 !
  • 213 Answers
F-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Posted on Nov 22, 2007
Shoot the guy who put bthat piece together cant get the beeping to stop shoot the ************** thats what i did
Posted on May 25, 2008
Try turning off the power then cleaning the electrical connections to the control board
Posted on Mar 09, 2008
Wat do i do the f7 keeps beeping
Posted on May 18, 2008
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
Sep 10, 2011 | GE Ovens
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
F7 error code
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
May 27, 2009 | GE JRP15 Electric Single Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE JGRP17 Gas Single Oven Logo
622 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
