Question about Iomega ScreenPlay TV Link Ultra-Compact Multimedia Player Media Players Digital Media Player
GETTING ERROR CODE HDD FATAL ERROR 50..CABLE TYPE RGA OR HDMI IS THE SAME ERROR CODE
  • 107 Answers
Do you hear any clicking sound when the player is switched on?
If so the HDD has become faulty. This normally happens when the player is dropped. You need to replace the HDD but if you are on warranty get a replacement for free. Never say you dropped it as the warranty will be void.
If you do not hear a clicking noise try to format the player and see whether it helps. Also look for the latest firmware upgrade from the manufacturer.
Posted on Jul 27, 2009
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Tally error code 2147483650 how to solve the problem
tally Error code 2147483650 how can i solve it
Nov 23, 2012 | Computers & Internet
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
ERROR CODE E602-0003 What is this?
E602
1) Are the connection and the cable of the connector (J1017) on the main controller PCB and the connector (J1551) on the hard disk drive normal? NO: Correct the cable connection.Hard disk drive (HDD), Main controller PCB
2) Try replacing the hard disk drive and downloading the system software.Is the problem corrected?
YES: End. NO: Replace the main controller PCB.
3) HDD unit.
Remove the rear upper cover and the reader rear cover. Remove the three screws, and detach the cover, Remove the two screws and disconnect the two connectors then, remove the HDD unit. Remove the six screws and detach the HDD When mounting the HDD unit,be sure that the flat cable is under the plastic sheet of the HDD upper case.
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then try to upgrade system software;If nothing works change hard disk ,format & install system software. Posted by Kuyung at 5:50 AM icon18_edit_allbkg.gif Labels: error code 602-0003 IR5000, error code 602-0003 IR6000
May 07, 2010 | Canon imageRUNNER 5000 Copier
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
No audio on pasma when cable set box set to certain channel
In that case two things might be happening. 1. HDMI/DVI cable you using might be faulty you want to change that or 2. The HDMI input of your TV set might be the problem. I will suggest you use component cable instead, I am talking about the 5-color-coded (green, blue, red and red/wihte) cable to connect the set top box to your TV.
Jun 15, 2008 | LG 50PX4DR 50 in. Plasma TV
Iomega ScreenPlay TV Link Ultra-Compact Multimedia Player Media Players Digital Media Player Logo
362 people viewed this question
Top Iomega Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Iomega Audio Player and Recorder Expert? Answer questions, earn points and help others
