Question about Dryers
The heating element should be nearly the diameter of the drum and is generally round. If the box of which you speak is about 4 to 6 inches square, it is probably an electrical connection box and shouldn't be getting hot. If this box has a removable cover, unplug the power cord and remove the cover--look for loose connections. If all ok, replace cover. Does the drum turn? Start the dryer and check for air blowing from the outside vent. If not, check for plugged lint filter (wash with hot water and detergent) and lint plugging the flex-hose between the dryer outlet and the outside vent. After running for a little while, feel the back of the drum to see if is generally hot--if so, then the heating element appears to be working. Hope this helps.
Posted on Jul 26, 2009
Feb 12, 2014 | Kenmore Dryers
Feb 20, 2018 | Bosch Nexxt 500 Dryer
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
May 03, 2010 | Kenmore 63942 Dryer
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dec 18, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Sep 10, 2009 | LG DLE2532W Electric Dryer
Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
Mar 10, 2008 | Kenmore 72622 Gas Dryer
Dec 22, 2007 | Roper RGX4634KQ Gas Dryer
Apr 19, 2018 | Dryers
165 people viewed this question
