Question about Electrolux Refrigerators
Water puddles in the fridge; function of green tag
We noticed that every time we open the fridge door of our Zanussi Electrolux fridge that a puddle of water has formed at the bottom of the fridge. We have the fridge for about four years and have never defrosted him. Please help! Also does anyone know the function of a green tag at the back above the salad compartments?
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
  • 109 Answers
SOURCE: puddle/ice in freezer compartment of my side by side
Take the back panel off the freezer, the drain tube is probably blocked, might have to melt all ice with hot water then take back off and clear tube all the way to the pan in the back
Posted on Jul 07, 2009
  • 10865 Answers
SOURCE: Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Jul 24, 2009
  • 146 Answers
SOURCE: Model #PSS26PSSA SS
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Posted on Aug 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have water puddling up under my Vegetable bins
Yes, Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 04, 2009
Why would my floor board on the drivers side have a puddle of water? I did just replace a heater core. i thought that would solve the problem.
So you're saying you replaced the heater core because water was puddling on the driver's side, but water is still puddling on the driver's side? I'm assuming you're in the US and the driver's side is on the left and the heater core is on the right side.
Do you get much rain where you live? Is the vehicle parked outside? Do you notice the puddling more often after a rain? If this is the case, your water intrusion may be because of a leaking seal around the windshield or door. Check by getting the floor reasonably dry, and then have someone sit inside while another floods your car with a garden hose - specifically the windshield and driver's door. Have the inside observer try to catch a stream of water along the edge of the windshield, along the door jam, or along the door sill.
Dec 08, 2016 | Cars & Trucks
Why do I have a puddle under my fridge every couple days but no sign of a drip or leak?
If it is an automatic defrost fridge the it will have a hose draining down into a container under the fridge, make sure it is draining where it should and has,not become dislodged. Some have a small tray with either pipes inside it or an electric heater. Some have a container sitting on top of the compressor, both of these are used to evaporate the water.
check to make sure there are no holes in the water catcher.
if you have an electric heater that is not functioning then the container will be already full of water and at each defrost cycle will overflow onto the floor.
Sep 08, 2014 | Refrigerators
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Fridge Freezer E402B not functioning properly.Solid red error light,with green light flashing up and dwn when push the = button.No air circulation to fridge,compressor seems to continious,also fridge
Natasha try this:
turn off the fridge's settings.
pull the power cord from the wall outlet
open the doors and keep them so for a few hours.
before these, take out the most perishable and keep in cool place.
after a few hours you may see a puddle of water under the fridge. clean the water and vaccum the fridge underneath and behind.
now reconnect power and set at recommended level. goodluck!
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
I have an EB9SHKXVQ refrigerator with the freezer on the bottom. Several times I've noticed a layer of ice on the bottom of the freezer under the basket. I have no idea where the water is coming from....
THE DOOR GETTING LEFT OPEN JUST A CRACK,OR HEAVY TRAFFIC...THE WATER IS COMING FROM THE DEFROST CYCLE. THE HUMID AIR IS BUILT UP ON THE COILS AND THE DEFROST CYCLE LETS IT MELT AWAY. YOU MAY NEED TO REMOVE ALL FROM FRIDGE AND START FRESH WITH A MANUAL DEFROST, USE A FAN THIS WILL SPEED UP THE (ABOUT 1.5HR) DEFROST TIME, WIPE DOWN FRIDGE N FREEZER TO REMOVE ALL MOISTURE, COAT DOOR GASKETS WITH ARMOR ALL, AND MAKE SURE THERE IS NO WAY THE DOORS CAN BE LEFT OPEN, BECAUSE OF SOMETHING NOT LETTING THEM CLOSE ALL THE WAY.. .. HOPE THIS WAS OF HELP.. JAY
Jun 22, 2011 | Whirlpool Refrigerators
Water puddling in bottom of fridge. water is
If the water to the ice maker is off then the source would be the defrost drain. I have put together some instructions on how to clean out the drain so the water will go to the proper place. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 17, 2010 | Electrolux Refrigerators
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
90 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
