Question about JVC AV-48WP30 48" Rear Projection Television
No sound. Picture is fine. Not muted. Hooked up another TV to cable box and it works fine. Kids mess with the TV and remote all the time but I've tried everything with no luck. I've worked on various electrical things but never a rear projection TV. Model# 52G886. It's four years old. Is this something I might be able to fix myself?
  • 1 more comment
  • randi46 Jul 26, 2009
    No luck with external speakers!
    Thanks for the reply. Is this audio board a "plug-in" or is it something I would need to solder in? Also how would I identify the audio board?
    Steve
    Benjamin,
    Thanks for your help. I'll give it a try.
    Steve
  • 3,037 Answers
Have you tried any external speakers hooked onto this tv yet? IF you have some, please try them as that will help narrow down the problem better.
Benjamin
Posted on Jul 26, 2009
  • Benjamin Patri
    Benjamin Patri Jul 26, 2009
    Ok, that means your audio circuitry is most likely at fault and the audio board needs to be replaced. You should be able to get one through a local shop or the manufacturer if you wish to replace it yourself.
    You may also try www.partstore.com
    Let me know how this goes
  • Benjamin Patri
    It should just be a plug in, follow the wiring from the speakers to the board, simple as that or get the replacement first and then you can match the replacement with the one in the tv.
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
No sound coming from TV....recently relocated and ran TV from cable box, have lost remote to TV and now cannot get sound to work...picture good just cant get sound?
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
Sep 21, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Feb 12, 2009 | Sanyo DP32746 32 in. LCD Television
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
I purchased the hdtv model DP32648 at walmart, I hooked it up, it is on and working , But some stupid guy told me I needed a cable called HDMI, OK So I have it But I have Dish Network, their is no place to...
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
Oct 15, 2008 | Televison & Video
Mitsubishi ws-65807 audio problem
First make sure that the audio cables for the cable box are plugged in. Second look on the front of the cable box and try to change the volume on the cable box itself most likley the volume on the cable box itself has been turned down.
Feb 06, 2008 | Mitsubishi WS-65807 65" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
