Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Removing protective diamond shield
How do you remove the protective diamond shield from a big screen projection tv and will this eliminate glare?
Dont do it
Posted on Jul 26, 2009
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
I just broke the diamond shield on my 2002 mistubishi. I need someone to replace it.
these tvs have 3 screens, 2 functonal, and the 3rd is just a screen protector. mitsubishi makes them so you can remove the protector to eliminate glare if you want, and its customer removable. if this is the only one that cracked, remove it and you will actually have a better picture. you just need a small flat head screwdriver. pry of the little plastic pieces at the top and bottom (some are on sides) that hold the screen in. its just held in on 2 sides, and then you flex it to get it out. if it cracked into the 2 screens behind the protector, you've got bigger issues and the repair could get expensive. contact your local mits service center for quotes, but the screens are atleast 100 each, just for parts. let me know if i can be of further assistance.
Jun 06, 2010 | Mitsubishi WS-48413 48" Rear Projection...
How to fix a big scratch on a projection tv screen
Is it the screen itself or the protective screen that is scratched. If it's the protective screen, then you can just remove that, but be warned the lenticular screen is now prone to scratches from kids, dogs or a clumsy significant other. But if you feel comfortable with no one bumping into it, then you can remove the protective screen and actually get a better picture quality with no glare.
If it's the actual lenticular screen (one behind the protective screen) then your in trouble and it will cost a pretty penny to get fixed. You can switch it out yourself once you buy a new one, but have two people handy, the instructions on how to replace should be in the owners manual.
Jul 19, 2009 | LG 30FZ4D TV
Diamond Shield for Mitsubishi VS45605
Unless you have small children it's better to just remove the diamond shield and throw it away. Less glare on the screen that way. But if you must have a new one go to a local glass shop and have a piece of plexiglass cut to the dimensions of the old one. We do that all the time and it works fine. Usually runs around $60.00.
May 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Diamond Shield Mitsubishi 55315
if either of u r close to michigan i have the above tv with no video possibly willing to part it out
Nov 11, 2007 | Mitsubishi WS-55313 55" Rear Projection...
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
TV Screen
Yes there are several and the ones I am posting for you have been used by folks who I know. You will most likely need to get the telephone number and call around, and they will probably need the exact dimensions of the screen good Luck http://www.projectorcentral.com/screen-suppliers.htm http://www.screens-usa.com/largescreendisplays/index.php http://catalogs.infocommiq.com/AVCat/mcs.cfm?mlc_id=223&SID=972124&mrc_id=1495&SUBCATID=1170
Jun 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
558 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
