Question about Friedrich QuietMaster RS10J10 Air Conditioner
Best height of inside unit of a split AC
What is the best height for an inside part of a split AC system for a total height of 3 meters.
thanks,,
    Champion:
  • 363 Answers
Which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Posted on Jul 26, 2009
My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Sep 16, 2015 | Heating & Cooling
Ductless AC 3 unit split system problem
They piped it wrong. They mixed up 2 of the pipes at the condencer.
Jun 21, 2013 | Heating & Cooling
A swimming pool is 7m long, 5m wide, 1m deep at the shallow end, and 3m deep at the deep end.The floor slopes evenly. What is the volume (in m3) of water in the pool?
The best way to solve this is to break the total volume of the pool up into two simple shapes.
The upper volume of the pool will be a simple rectangular solid with the following dimensions:
L=7m
W=5m
D=1m
Volume of this section = L x W x D = 35 m^3
Now the lower volume of the pool will be a a triangular prism solid with he following dimensions:
Base=7m
Height=2m (3m total - 1m top section)
W=5m
Volume of this section = 0.5 x B x H x W = 35m^3
Now just add these two sections together to find the total volume of the pool:
V1 + V2 = 35 m^3 + 35 m^3 = 70 m^3
Therefore the total volume of the pool is 70 cubic meters.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 29, 2011 | Office Equipment & Supplies
How many tons in 3 cubic meters sq by 3inchs deep
I am sorry to say it but your units do not make sense: Units of volumes and areas are mixed up.
Let us try to make sense of it.
If you have some container whose base is 3 square meters (not cubic meter sq) and it has a height of 3 inches you can calculate its volume in cubic meters or in cubic inches or cubic feet. To do so convert the height in inches into meters and multiply the area of the base by the height in meters and you will obtain the volume in cubic meters. To get the volume in cubic inches convert the area of the base to square inches and multiply by the height in inches.
However, even after you have expressed the volume in one unit or another (m^3 or in^3) you cannot find the mass of the substance contained (be it in tons, tonnes or kilograms): You need to know the substance and more specifically its density or its specific gravity).
Please, reformulate your question and specify the substance that fills or would fill the volume. Without that information, nothing doing.
Apr 08, 2011 | Office Equipment & Supplies
I am looking to buy a mini split ac/heating 1 ton unit. I want to know how high from the floor does the unit have to be to cool and heat a 10 x 20 room?
Hi, when you buy your split system, the indoor unit will mount on your wall off off the floor a distance that the factory has made it for. With an 8' to 10' ceiling, it would be about 7' off the floor. This all depends on the refrigeration plumbing coming from the outdoor condenser to the indoor unit. It will tell you all of this on the installation kit for this unit, as the plumbing for the freon pipes are already pre-made for a certain height. A 1 ton, (12,000 btu) unit will have no trouble cooling a room of this size, so check with the manufacture on the height it will be.
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Goodman Heating & Cooling
How do I gain access to the fan which is located on the inside of the unit of a split aircon, the unit which resides inside the house. Need to pull this part out off the unit to clean it. Thanks
is this a split system on your wall or a cassette(a square unit in the middle of the room) like in the picture? units on the wall are very annoying to get out and if you do you will probably brake it. best to just turn of the unit and whip and spin whip and spin with a long brush or stick with a cloth on it.cassette units you unclip middle filter plastic panel then theres a fan use a shifter to undo ?
Oct 29, 2010 | Cfm Daikin R410a Split System Air...
Hey, thanks. I have a bosch split AC. It puts drops of water all the night inside my room. Why do you it is doing that.
You say a split unit I am taking for granted its a split but not a central unit. If this is true your drain line from the inside unit is kinked or plugged. Common problem. good luck
Aug 12, 2010 | Heating & Cooling
Split ac runs for 2 hrs and MCB TRIPS
The most common reason is that the electrical power is not supply to the air conditioners. If the air conditioner operate for period of time then only it trips. Then , it could be possible that the MCB is under-sized. Please check the recommended MCB size.
Rate it.
Mar 02, 2010 | Heating & Cooling
Best split ac 1.5 ton
I think you just have a faulty unit. Most of the mid wall split units have similar components and there are only cosmetic differences. Lg is strangely enough a good aircon. Personally i like Samsung .(Spares are easily available). You should concider who the best after sales service supplier is and go that way. (As stated, most units are similar in my oppinion.)
Sep 21, 2009 | LG Heating & Cooling
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
Friedrich QuietMaster RS10J10 Air Conditioner Logo
222 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
