Spacebar came off
My spacebar came off and so did the little white pieces and now i dont know how to put it back on. HELP!
  • carri-jay Jul 26, 2009
    iv looked on youtube and i cant find anything that's similar to my laptop which will actually help me
    The little white pieces are the retainers and I have a laptop
    Brigadier General:
  • 4,088 Answers
There shouldn't be any 'little white pieces' Something caused the breakage like trying to remove the space bar to clean it. Best solution--buy a new keyboard. They are quite reasonable.
Posted on Jul 26, 2009
    Sniper:
  • 86 Answers
Fairly straight foward look on you tube there are plenty of people with step by step on how to
I took my spacebar off to clean it and i dont know how to put it back on?
There is a rubber part that is designed to spring up when you release the space bar - this is the contacts that is the electrical push button. At each end the metal bar is hooked to the plastic (the long space bar key). There may be a couple springs found as well - they should seat on the base. Connect all pieces and place the space bar key over the area where it aligns to the keyboard and snap it place with a slight force.
Nov 23, 2010 | Compaq Keyboard
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
I.removed.the.laptops.spacebar.and.i.cannot.get.it.back.in.there.seems. to.be.4.little.pieces.of.white.plastic.and.two.thin.metal.wires.on.the....
The two pieces of metal should snap into small slots on either side. Then you press it straight down so the plastic piece locks into the button on the membrane on the keyboard assembly. Good Luck
Jul 28, 2009 | Acer TravelMate 5720-6462 Notebook
Spacebar,wont,work,after,spillin small,amount,of,juice. took.rubber,piece,off,of,my, spacebar,and,cleaned,it. but,can't,get,it,back,on. This,is,on,my,laptop
The sugar goes into the contacts and permanently deamages the keyboard. NOT REPAIRABLE. The laptop keyboards are not very expensive. You will only get that problem solved by replacing the keyboard.
Jul 20, 2009 | Logitech 967437-0403 Keyboard
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Spacebar key wont click back on
I find the trick to putting laptop keys back on is to extend the little arms completely up. (it looks like an X from the side) then put a very small screwdriver on at least one side to stop them falling back down, then press the key on firmly but gently. The top of the arms should click into the underside of the key, then you should have its springy-ness back.
Let us know!
Feb 05, 2009 | HP Pavillion ZV6000 Notebook
Camera won't play or record
Please insert roller on pinch roller shaft and put white plastic piece (lock) on it. Roller location is shown in below exploded view of camera mechanism.
Need further info / help, let me know.
Oct 27, 2008 | Sony Handycam CCD-TRV108 Camcorder
I took off the spacebar and now i have trouble putting it back on to work properly
Just separate the retainer from the spacebar as good as you can and then put it in the little hooks on the left and right sides and then angle the key a little bit and snap it on. It took a while for me but I did it! :)
May 07, 2008 | Microsoft Internet PS/2 Keyboard - OEM...
Spacebar does not work.
sounds like the rubber is stuck, take off your space bar (make sure you can put it back), make sure theres nothing on the little rubber peices, and put it back on
Jul 25, 2006 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
