Question about Lexmark X5470 All-In-One InkJet Printer
Printer makes grinding noise and not printing
Lexmark X 8350 - When I try to print, I hear a loud noise like gears grinding, then get a message that the paper is out when it is not.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Posted on Jul 26, 2009
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
thanks
alamri
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
HP2420N printer makes a loud grinding sound when printing
This printer had change made to some drive gears. They wear down and cause this noise. If you can find a technician to replace the 3 gears it can be inexpensive. We do it for under $150 with labor and parts.
Apr 15, 2010 | HP LaserJet 2420 Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
488 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
