Question about Lexmark C533DN InkJet Printer
I just created a new document, and when i push print, nothing happens except printer gives me a copy of something else. how do i get my printer to print the new page? thanx, babawawa1
  • 164 Answers
Go to printer and faxes and look to see if there are print jobs "stuck" in there. If so,click on documents and delete all print jobs. Then as an extra precaution, right click on "My Computr" and select manage..go to services and applaications..select services..drill down and find "Print Spooler" and stop and restart the service. Try your print job again
http://www.aa1consulting.com
Posted on Jul 26, 2009
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
PSC 1315v won't print
When you go to scan and the power light flashes, that tells you your computer IS communicating with the printer, however it may not be a good connection. Below i described that more. If the connection is indeed fine, and you tried a second pc or re-installed software completely, then I would have to say the printer is dead to you. (ie. a chip on a logic board has failed). Please continue below.
Software may be at fault. Can you print a demo page on the printer? Generally it can be done without a computer connected even, just hold any large buttons on the front of the printer for a few seconds, lights should start flashing, and a test print should print. I bet it will, because you said it "copies without a gripe."
IF that works, maybe you can completely un-install the printer software from Add/Remove Programs, or you can install it on a second computer?
IF that does not make a difference, try a new USB cable if you can. OR See if the USB port on the back of the printer appears loose. Are you able to hold it upwards or downwards or move it around at an angle? You could print another page, and quickly hold the cable in, and pushed up at an angle, or pushed IN-AND-DOWN at an angle.
IF that can be confirmed, you would need a $1 store soldering iron and would have to take the printer apart, and heat-up the connections between the USB port and the logic board. Possibly need $3 of solder from radio shack or what not. Hope I
Sep 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Too many printers listed
Not sure what happen to this but I had the same problem. What you need to do is highlight each one except the first HP Photosmart 4100 series, and delete all the other ones.
So delete the following 6 printers.
Send to One Note 2007
Microsoft XPS Document Writer
HP Photosmart C4100 series (copy 1)
HP --------------------" ------" (copy 2)
HP....................................(copy 3) AND
HP ..................................(copy 4) which is the only one that works!!!!!
Now the one that is left should be the default. Do a test page or print something out to make sure.
This should fix your problem. Please rate.
Feb 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Lexmark C533DN InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
