Question about Philips Televison & Video
My dvd/vcr combo won't open any drawers on a magnavox combo, i press open and nothing opens, nothing seems to work except the lights
    President:
  • 1,188 Answers
You need to change the drive belt. Attempt only if you know how to replace electronic parts. Open top cover and see drive bay to locate any belt that opens the door. Replace it with a new one. Also apply a little grease to the drive's edges.
Posted on Jul 26, 2009
No valid code to use my Sony Remote with my Magnavox DVD/VCR combo
have you tried ? 60000 60035 60039 60081 60593 61593 (VCR)
if the codes for the DVD didn't work ...
Jan 05, 2014 | Magnavox Televison & Video
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Combo dvd vcr tray won't open
The belts are under the VCR tray and under the Disk tray.
Feb 15, 2010 | Panasonic Televison & Video
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
THE DVD DRAWER WILL NOT OPEN!!
Try using paper clip to open your dvd drawer.
Mar 03, 2009 | GoVideo Go Video DVD/VCR Combo
DVD Drawer won't open-- paperclip method isn't working
Unplug it. You'll have to open the cover. Then you may have to remove the tray assembly from the frame. On the bottom you will be able to access the belt. If you're luck, it might be in another location on top or off to the side.
Apr 25, 2008 | GoVideo VR2940 DVD Recorder/VCR
Dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Jan 20, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd drawer will not open
seems like the rubber band is broken. no there is not secret back door to it..you have to open it and change the rubber band. it is not that complicated
Mar 26, 2007 | Philips DVD750VR DVD Player/VCR
Televison & Video Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
