Question about Sony Xplod XM-554ZR Car Audio Amplifier
20-Volt DC Power Supply instead of 12-Volt amp
I want to use the Sony Xplod XM-554zr in my room and i only have 20 volts power supply available instead of 12 volts supply for this amplifier. Anybody please can share any idea if this voltage range is still safe for this amp.
    Genius:
  • 1,114 Answers
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Posted on Jul 27, 2009
I have a pioneer car stereo-12V DC, a sony xplod amplifer(2 chanel)-12V DC and I want to use them in my home, what kind of power supply will I need?
You want to use a 12 Volt power supply. This takes your 110V power and converts it to 12V power. Which size you need completely depends on how powerful your amplifier is. Your stereo needs about 10amps of power and looking at the fuse size on your amp, you need to add thses to the 10 amps for the stereo and this will tell you what kind of power supply you are looking at.
Aug 09, 2010 | Pioneer Car Audio & Video
I NEED TO KNOW HOW MANY AMPS YOU NEED TO SUPPLY TO RUN A 600WATT AMPLIFIER CORRECTLY? AND ANY SUGGESTIONS ON WHAT I SHOULD USE TO POWER IN IN A HOUSE?
if you have an old pc you can use the power supply to power your amp in house make sure it is +12v 10-16 amps be carefull make sure your voltages a correct with a vom
Apr 18, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Can i run my xplode amp from my pc
Thanks for using Fixya.
Yes you can... but, this will cause you a lot of hassle. You'd need to get yourself an AC/DC converter because your amp needs 12 volts. Do not use your computer's power supply unit for the 12volt input as your amp eats up alot of power so you might overload your computer's power supply unit (PSU). After getting the AC/DC converter for your amp. You need to rewire your audio input going to the amp so that it uses a 3.5mm jack so you can easily plug it in to your computer's audio output. I hope this helps.
Thanks and have a nice day.
- HotRatchet
Nov 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Car stereo keeps shutting off when I put it in park or neutral
The Capacitor may be bad. Try hooking it back up w/out the cap. see if it works the way it use too!
Sep 21, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
RADIO STATIONS WONT STAY
This is simple the memory wire (yellow) is connect incorrectly. It needs 12 volt constant or continously. meaning 12 volts even when the car is off.
Dec 06, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Cant get amp to work
there are two nobs on the back of the amp they have to be turned inorder to ajust the woffer vol. make sher its not in power safe mode that will be a red light insted of a green one
Sep 16, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
My amp works on tuner but switches off when i change it to cd
The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
Jun 16, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
145 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
