It depends on what outputs are available on the TV, but the best you could do would be via an optical (fibre-optic) lead from the TV to the AVR for digital audio, which might give you surround sound. Failing that, you can use a phono lead to get analogue stereo audio. The ideal would be HDMI but the AVR doesn't support this.
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
SOURCE: How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
SOURCE: Don't know where to hook cable wire into my W4207-Flat Screen
Nice tv - but its a monitor, so there will NOT be a RG6 cable connection on the set. you have to provide a tuner to get signals OR use a cable box, sat box, etc.
SOURCE: how do I hook up my hp computer to my lg flat
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
