Question about Kenmore 24032\24036 Top Load Washer
24032 \ 24036 Top Load
I have a blouse wrapped around the bottom of the agitator. Any way to remove it?
  • 636 Answers
Unscrew the knob on the top of the agitator and remove the agitator.
Posted on Jul 26, 2009
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
Jul 27, 2014 | GE GTWN3000MWS Washer
Trim on blanket caught between agitator and drum. How do you remove agitator on this model?
The agitator simply lifts off the shaft. Grab it and pull upward with a little force, and it'll pop free. Under the agitator you'll find a plastic drive coupler that has a single bolt through the top. Remove this bolt and remove the drive coupler. Whatever got wrapped around it you'll find underneath and should easily come out now.
Aug 16, 2013 | GE GTWN5250DWW Top Load Washers
I have a kenmore top load washer, The top part of
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following on how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Oct 28, 2009 | Kenmore Washing Machines
Adgitator removal
Just follow these steps:
1. Remove the center dispenser from the top of the agitator. It should just pop off.
2. Locate the white plastic cap underneath and pull straight up to remove.
3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
If you have questions, please let me know. I hope this helps you.
May 03, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
A sweatshirt cord is wrapped around my HotPoint top load washing machine. The machine is 18 years old. Can I pull off the agitator to retreive the string?
If it's wrapped around up underneath the agitator you can.
Have you tried just figuring out which way it was wrapped?
Keep a can of WD-40 handy.
Jan 29, 2009 | Hotpoint VBXR1090B Top Load Washer
Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Dec 25, 2008 | GE WBSR3140DW Top Load Washer
Agitator removal
Yes it does, I believe the dispenser will twist an 1/8 turn and pop off. There is a cap with a handle below it that pulls out. The last part is a bolt. Try a 7/16 deep well socket with a nine inch extension, grasp the agitator and loosen it. Leave bolt intact and lift agitator from the bottom. Looking from the date if you have solved the issue this will stand as a general post for ag removal.
Jul 31, 2008 | Kenmore 22422 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
73 people viewed this question
fordexpert
Mike Squire
Robert Rankin
