Question about Refrigerators
Is there any way to fix scratches on the door of the refrigerator. We have a ultra satin finish.
    Champion:
  • 363 Answers
Go to appliancefactoryparts.com, they may have satin touchup paint, or go to an appliance store
Posted on Jul 30, 2009
Knob does not come out all the way into the door frame for closure. why?
Most common reason for this is the hole its going into on the frame is either not deep enough and/or the hole and strike plate/larch are not properly aligned (i.e. its hitting the side of the wood etc.,).
Mar 01, 2015 | Ultra Satin Chrome Exterior Entrance Key...
How do i fix scratches on my LG LBN22515SB fridge
Go to your local hardware store and get "appliance paint" and respray the doors. Be sure you only get appliance paint!!
Apr 06, 2013 | Refrigerators
Can a brushed nickel soap dish cause green spots to form on white soap
if the finish is scratched and it is brass underneath, yes. Otherwise, no.
Oct 03, 2010 | Grohe Satin Nickel Soap Dispenser...
Scratch on the front panel, how do we repair. Does it have to be replaced?
Scratches aren't an easy or inexpensive fix. However, if, like most appliances, your's has a protective clear coat on it, you can try using a small applicator (like a Q-tip swab, etc.) and a very, very light amount of clear lacquer and lightly dab it onto the scratch and quickly wipe off the excess with a clean, lint free, cloth.
You can buy a can of clear aerosol lacquer that closely matches the type of finish on the fidge panels, (matte, satin, gloss).
The trick is to NOT spray directly onto the panels, but rather spray a small amount into the cap of the aerosol and using the swap, dip it into the liquid and, again, dab it lightly onto the scratch.
Another option is to purchase one of those automotive scratch repair kits that you see advertised on TV or in auto parts stores and follow the directions for fixing the scratch.
If you take your time and go lightly and carefully with the application, you can get a pretty decent repair that will make the scratch all but disappear. If it's also dented, then you've got another issue to deal with, but in any event, attempting a repair of the scratch will cost you hundreds of dollars less than buying a replacement door panel.
I hope you find this Very Helpful and best regards!
Oct 14, 2009 | KitchenAid KSSC36FMS Side by Side...
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Scratches on door with stainless satin finish. Is there any way t
the only way is to buff it with a graining wheel on a buffer try sheet metal guy
Jul 27, 2009 | Refrigerators
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Long scratches on my LG Titanium refrigerator door. Is there a way to fill or buff out?
Unfortunately there is no way to fix this problem. The doors can't be "buffed" out to repair scratches. The only way you can fix scratches on the refrigerator is to buy "touch up paint" from LG and it is only for the sides of the refrigerator. To fix this problem you will have to purchase a new door. You can call LG Parts Dept. 888-393-6484 to purchase this door.
Apr 28, 2008 | Refrigerators
Scratches on stainles steel door
IF IT IS BRUSHED STAINLESS, AND THE SCRATCHES ARE REALLY BAD, YOU COULD TRY SOME STEEL WOOL TO SOFTEN THE SCRATCHES, BUT IT WILL BE A TRADE OFF OF MINIMIZING THE SCRATCHES AND CAUSING A SMEARED LOOK TO THE BRUSHED STAINLESS PATTERN.
Apr 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
Repair scratches on black door front
Mr....other than repainting, the only suggestion I have is one of those scratch repair kits that they sell at Pep Boys. The finish materials...paints...not stainless...are about the same as used on cars. Use a soft lambswool bonnet buffer and go slow.
If it is stainless...use 00 steel wool in a one directional sweep with a little bit of light oil.
good luck, sir.
Dec 03, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
314 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
