Question about Midland 75-822 40-Channels Handheld CB Radio
I have the midland 75-822 and am having problems. The thing constantly flashes "Save" and the signal strength moves up and down while the "Save" flashes. I can't hear or key the mic while this is happening. This is the second unit that has done this. I have it hooked up to an external annteana and a 12v power source.
Could you elaborate on how to disable the power save circuit on the radio. Thanks.
Posted on Jul 14, 2010
  • bayareajacks Oct 27, 2010
    Has anyone come up with a solution to this problem? I just opened my box and I'm having the same problem - flashing save every 15 seconds and a click noise.
    Novelist:
  • Midland Expert
  • 500 Answers
Theres a setting to turn off the power save circuit to be able to use the radio. or you need a larger ampre 12v source.
Posted on Dec 08, 2009
  • davidhead894 Jul 15, 2010
Iphone 4 lost signal,when try to make a call
Sounds like a problem with the radio transmitter in the phone. You will need it repaired or replaced I fear.
Apr 05, 2014 | Apple iPhone 3G
Tip
What to do if you cannot make call on your phone.
Before you even start trouble shooting ask yourself whether your phone may be barred from the network if it is stolen or the account holder did not pay their bill....If this is not the case then ensure that your phone is powered on. Hold the power button down for a full 3 seconds. (The power button is often located on the top of your phone. Please refer to your user guide for the location of the power button for your specific phone). Confirm that your service is active. If you are unsure, contact your service provider.
Check that you have sufficient network signal strength. When you are at the start screen or in a call, the strength of the radio signal is indicated by the signal indicators on the left side of your phone's display. These indicators move up as the strength of the signal increases and down as the signal decreases. To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
If you are still unable to place a call, please contact your service provider. If they are unable to assist you, please submit your phone so it may be inspected for repair.
on Sep 28, 2010 | Cell Phones
I have the router right by my PC, it appears connected but no signal strength at all (no bars) what is wrong?
try changing the wireless channel on the router and see if that makes any difference.
Open the setup page of the router.
Go to wireless tan and change the standard channel to 11. save the settings.
You can also try updating the drivers of the wireless adapter on your computer.
If your router is too old then you must upgrade the firmware on the router.
See how to upgrade Linksys router firmware
Mar 21, 2012 | Linksys Wireless-G Broadband Router
The vocopro 5800 is constantly losing signal strength and going in and out with movement. How do I fix this problem.
1. Check microphone(s) batteries and replace if the
charge is low.
2 Remove local sources of UHF interference, such as
lighting equipment.
3. Adjust the squelch controls on the front of the UHF-
5800 receiver.
4. Signal may be too weak. If so, reposition antennas.
If possible, move them closer to the transmitter.
5. Reposition the receiver, perform a "walkthrough",
and observe the signal strengths. If audio dropouts
persist, mark these "dead spots" in the operating
area and avoid them during the performance.
If none of these could help it is possible that the device has really some faulty operation and needed to carry it to service center.
gylacz
Mar 18, 2011 | Audio Players & Recorders
Hi i have a midland alan 78 plus multi and it will not receive or transmit ,when you press the ppt button there's no signal strength showing on the display , the power supply is good and worked fine last...
hello there your problem is simple the final transistors have blown as you have no audio an audio transistor is also required best leave it to the pros to repair goodluck
Dec 17, 2010 | Midland 40-Channel CB Radio CB Radio
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
Durabrand TV/DVD dct1481
The blue screen is fairly common and is displayed when inadequate signal is present.
In other words, 'no reception.'
The weak BBC1 signal is kind of a confirmation of your poor signal strength.
Aug 20, 2008 | Durabrand DWT1905 TV
Keeps flashing check reception
I unplugged mine, took out the back up batteries, and waited several minutes.
I reinstalled the batteries, plugged it back in, and reset the time.
For now, it seems to have solved the problem.
Dec 10, 2007 | Midland WR-100 Weather/RDS Radio
Midland 75-822 40-Channels Handheld CB Radio Logo
585 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
