Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mod # 944.609800..20.5 hp/42...Tranny drain location?
Mod # 944.609800..20.5 hp/42" deck..where is hydrostatic tranny drain plug??
  • 376 Answers
There's not one.
Posted on Jul 29, 2009
Diagram for hydrostatic drive
Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid isactually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Tuff Torq Lawn Garden
Apr 07, 2015 | Garden
What type of oil goes in a craftsman dlt 3000 hydrostat tranny
Mar 25, 2015 | Craftsman Garden
What oil do I use in my ***** hydrostat?
Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like mobil). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Sep 25, 2014 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Drive train wont shift
is this unit a manual shift or an hydrostatic type? If it's a manual shift then it's either the linkage or the tranny itself. If it's hydrostatic it could be a number of things. Further investigations will have to be done here. Hydrostatic is just an hydraulic system with a wash plate and it's the angle of the wash plate that determines the direction and the speeds.
Dec 18, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
What are the basic maintenance tips needed to maintain my lawn tractor L145 22 HP, 42"? Ex: What needs to be greased, when do I change the oil ect? Thanks Larry
Engine oil should be changed every 50 hours of use or annually, whichever occurs first. The oil should be a 10W-30 and it takes about 1.5 quarts with filter change. Check/clean the air filter every time the oil is changed. After cleaning the filter, hold a light to the filter to see of there is light coming through. If the light is very faint or none at all change the filter. Spark plugs can be changed every other oil change. The front axle should be greased every service, there is a grease fitting on each side of the axle towards the top of the spindle, by the wheel. There is also a grease fitting on each blade spindle. They are not easy to grease without taking the belt shields off. Also check the bearings on the deck by grabbing the pulleys and try to rock side to side. Check the belts for cracks, and make sure the tire pressure is set right. If your tire pressure is off the mower will cut uneven. I usually set tire pressure 10psi for the rears and 12 psi for the front. Hope this is what you were looking for, Daniel.
Sep 05, 2011 | John Deere 22HP Hydrostatic 42" Riding...
2007 craftsman sy 4500 42" mower will not climb small incline. any suggestions?
sign of a failing hydrostatic tranny. however 3 years is pretty quick for a transmission unless mower was used commercially. make sure your drive belt is snug.
Aug 26, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
317 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
