Infinity subwoofer in surround sound system was working and just stopped. Fuse is good but subwoofer just stopped working like the preamp blew. This occurred during low volume usage.
    President:
  • 1,114 Answers
Check your speaker settings on the main menu of the receiver first. If you still have an issue, post a comment and I will help you troubleshoot some more
Posted on Jul 27, 2009
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
I have a 2005 scion tc, everything stock. My bass just stopped working, the treble still works but there is no bass. Does that mean i blew my speakers? They still sound fine. Is there anything I can do...
check your fuse box and find which fuses go to your radio/audio system it may have a built in subwoofer and amp in the vehicle -check those out and hopefully it will solve it.good luck.
Dec 10, 2010 | Car Audio & Video
My subwoofer atarted making deep humming sound, then stopped working. I changed the fuse and then when i turned it on it blew the fuse. What can i do?
The voice coil of your woofer is off centered and shorting on the armture causing the speaker to draw too much current. The fuse blew thereby protecting the output stages of your amp. Replace the speaker.
Mar 17, 2010 | Polk Audio PSW150 Speaker
My Infinity sub-woofer for my home surround sound system will not turn on. The power light wont even turn on. What can I do to repair this? It seems that no electronic place with repair infinity speakers...
Open it up and see what is in there! You might find a fuse blown. It might have just blown, without a fault, if you are lucky. If not check out the part numbers on the amp board. All semiconductors numbers, then put the numbers into google. You will soon find out if they are obtainable!
Jan 19, 2010 | Infinity PS-10 Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Fuse blew and replaced, now sounds bad, what happened?
Fuse is blown because you may have bad DC to DC converter circuit (step up circuit from 12vdc to provide +-/- 30~40vdc) that supplys the power amp section. I can be that the output stage of the amp shorted out and it took out the DC to DC converter circuit.
Oct 31, 2009 | Infinity BassLink II Car Subwoofer
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
233 people viewed this question
 Grubhead
Grubhead
