Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
It will work ok sometimes but, most of the time i only get a partial display of numbers on the lcd screen.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
If this unit is less than 2 yrs. old.....Sent it to Bushnell and they will replace it under warranty at no cost to you. 800.423.3537
MTG
Posted on Jul 27, 2009
System freezes-Video display=multi-staggered image(not legible)
It's either a loose connection from the motherboard to the video-display, or a partially-broken video-display, or the video-adapter in your motherboard.
Connect an external monitor -- if it looks OK when the internal LCD is "wavy", then your computer is fine.
But, since your say "happens to both screens", the most-likely problem is the video-adapter, which usually means that you will have to get COMPAQ to replace the motherboard.
May 26, 2010 | Computers & Internet
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Display is very faint, disappears
replace the inverter board below the lcd panes  with same part number.if it is in india i can help you
Mar 10, 2009 | Dell Latitude 110L Notebook
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
An area on the display it's not working. PowerBook G4
I'm sorry to say that you will have to replace the screen soon. That vertical black and white lines that appear is the early warning signs that your screen will soon go blurry, or have a partial screen, or have it just stop working. This happens from the many times the screen was lifted open and closed and the ribbon cables just need to be replaced. And since the ribbon cables can't be simply unplugged and then replaced, you will just need to get a new replacement screen.
-Luke
Dec 20, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
LCD screen partially display's
This kind of issue is usually due to a loose inverter cable, re-seating the cable is a relatively simple matter.
If the laptop is still under warranty you should contact Dell to have it repaired, if on the other hand it is out of warranty you should shop around for a repair quote unless you are absolutely confident you can strip and reassemble your laptop.
Mar 13, 2008 | Dell Inspiron 6400 Notebook
Change LCD screen back to English
Issue: How do I change the language setting of the LCD?
Solution: Change the display language settings (MP170)
LCD Appears in Japanese (or other foreign language) Upon powering on the machine for the first time, the LCD will prompt to select a display language. If a language other than English is selected, the setting can be changed by following these steps.
  1. Ensure the machine is powered on.
  2. Press the <Menu> button as many times as necessary to display [SYSTEM SETTINGS].
    1. From the Copy mode standby screen, press <Menu> 7 times.
    2. From the Scan mode standby screen, press <Menu> 1 time.
    3. From the Memory card mode standby screen, press <Menu> 6 - 12 times.
  3. Use the right arrow twice to select [OTHERS] and then press the <OK> button.
  4. Use the right arrow three times to select [LANGUAGE SETTING] and then press the <OK> button.
  5. Use the right or left arrow to select the appropriate language and then press <OK>. Choose from the following language settings.
    1. JAPANESE
    2. ENGLISH
    3. GERMAN
    4. FRENCH
    5. ITALIAN
    6. SPANISH
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
426 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
