Question about LG DLE5955 Dryer
Has power, won't start after lightning storm - LG DLE5955 Dryer
  • mr_prosser Jul 26, 2009
    Any way to check the board?
    Confirmed our suspicions. Thanks
  • 6,784 Answers
HI, i am most certain that the power surge has fried the Main Pcb Board assembly. you will need to replace this damaged PCB asap, If possible.
Part Number: EBR36858801
Posted on Jul 26, 2009
  • Michael Masters
    Michael Masters Jul 26, 2009
    NOTE((It is recommended to replace the PCB Display as well when a power surge has been detected, as in this case. Normally, a surge will carry enough current to damage all connected board that are linked to the main))
    Part Number: EBR36858901 (PCB DISPLAY)
  • Michael Masters
    This board can only be replaced and not repaired. yo can confirm by looking at the display. If the display is illuminated but, not operable, this will confirm Main failure. if the display is not illuminated when plugged in, this will also confirm Main failure. the display is directly wired to the main, any damage absorbed by the main will be transferred to the PCB display. as well. An additional test will be to use the pin points on the Main connectors for testing. with a meter, you can test for live current to the board. any connector will do. If you notice any reading and, the board will not operate the unit commands, this will confirm circuit failure.
    The inoperable control functions that you sated are a strong indicator of Main BOard failure.
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Aug 09, 2012 | Televison & Video
I have a nintendo 64 that turns on and has sound but no video output. I have tried 3 different connectors including a gamecube one that has always worked with my gamecube and still does. Is there anyway i...
Well I think that the console might of had been damaged by lightning thats why when theres a thunder storm you should always unplug your consoles so they won't get hit by lightning I always unplug mine when theres a thunder storm. Well the sound module inside of the console is broken then so you could send it into console solutions then they repair old systems too.
Aug 16, 2011 | Nintendo 64 Console
Dell 4600 won't power up following lightning storm. PSU and power button both test OK. Suggestions please! many thanks
Check everything between the power supply and the wall outlet. If everything else is working using the same power a part of your computer is fried.
Jul 27, 2011 | Dell Dimension 4600 PC Desktop
Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Jun 28, 2011 | Sony Televison & Video
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
LG DLE5955 Dryer Logo
83 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
