Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
I have the same problem. 1199VSR hammer drill. The tool is 18 months old (out of warranty) and has barely been used - I think I used it for for two jobs - all together about 12 1/2" diameter holes. It runs fine in reverse. It starts occasionally in forward - perhaps 1 time out of 10. When it does start in forward it will just cut out randomly.
  • david41045 Jul 29, 2009
    A question for those of you who have repaired these before - if I order the brushes from Bosch, do they come with new springs? I can't seem to find a part number for the springs individually.
    Thanks, David
  • david41045 Jul 31, 2009
    I opened up the back of the case (to get to the brushes) and the brushes and springs look fine. There is no sign of burning or discoloration and the brushes have plenty of length to them.
    Are there any electrical measurements I can make to verify the brushes are really OK?
  • 5,603 Answers
This piece of junk tears out the brushes time after time. Mine were replaced 4 times under warranty. Finally gave up. The brush holders will not take the vibration of hammer drilling. It is a design problem. Repair the unit and use ONLY for straight drilling.
Posted on Jul 29, 2009
  • Fred Yearian Aug 02, 2009
    My unit caused the brushes to chip and become very angled. At that point they would stick a bit in the holders and not make contact. Vibrating the drill could get them to contact for a bit and running in reverse it would do that, but once hammer drilling in forward was started the brushes would bounce out of contact and jam away from the commutator. Same thing happened after several warranty repairs for the problem.
    Brigadier General:
  • 4,088 Answers
Check the motor brushes for breakage, badly worn, or weak springs (heat damage). Keep track of brush wear pattern when removing and reinstall in the same orientation.
Posted on Jul 26, 2009
  • drallim Aug 01, 2009
    If you can, run the drill with the brushes exposed--first in reverse and then forward. Look for bad sparking where either brush touches the commutator. If it won't run in forward, try turning the chuck in the forward direction somewhat (tighten the chuck beforehand) to check for intermittent brush contact. If the brushes don't display any particular problem, then suspect a bad forward/reverse switch or a loose wire to the f/r switch.
My 1199vsr is not getting power
check motor brush maybe stuck in dirt
or power cord conductor cut
Nov 20, 2012 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
I used my 1199VSR without the right size extension cord (too small of a A.W.G. size) but dont recall a burn smell. When using the extension cord it was working fine then started going slow and then it...
Howdy, I am willing to confirm what I believe you already know; it's cooked. Now about fixing it You can do it yourself with bosch parts for almost the cost of the drill, or have it done for somewhere between free and ? by Bosch depending on how long you have had it. Bosch has a prorate form of warranty repair that sometimes works out really well.
Whichever way you choose to go, this link will help you it get dealt with pretty darn quickly:
http://boschtools.com/Service/ProductServices/Pages/ezship.aspx
Hope this helps some:)
Regards, Farmerbear at FixYa.com
Sep 08, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Grease type in power tool
Most tools use grease that is supplied by the tool manufactures and you can purchase it from the proper service center. In an emergency you can use a standard ep2 grease but usually this standard grease will shorten the life of the tool or cause it to fail completely so it should be washed out as soon as possible and replaced with the proper grease the factory recommends
Jan 03, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 1199vsr stopped working while drilling through concrete. The reverse works. Help
your tool should have a rotating reversing switch and the contacts for the forward rotation might be dirty or burnt. I would unplug the tool and remove the screw holding the back handle half on and look to see if anything is burnt or just dirty or bent. If you have an air compressor try blowing thru all areas of the tool. Let me know if this doesn't work you can also go to Boschtools.com and type in your model number on the left hand side after clicking on manuals.
Jun 28, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Unit wont turn on
Hi
First check the power suply cord(the conductivity),the on/off switch,the brushes,the fan and the armature.The wires too.
best regards savumihai71
Jan 16, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
508 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
