Question about Onkyo TX-SR502 Receiver
Issue with Onkyo TX-SV919THX, no sound
I have a similar problem, and have located and removed the battery from the unit, where did you find a replacement?
hi-fi
  • 25 Answers
SOURCE: My Onkyo Receiver TX 601 is turning itself off
Adjust bass control to half position then feed loud signal,if it shut off adjust the bass contol to zero position,if it shut off again the defect is in the over load protection circuit it is already sensetive to loud signal.you may call the nearest audio amplifier technician on you.
Hope it may help you,
Posted on Dec 29, 2008
petraman7
  • 1175 Answers
SOURCE: problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Posted on Jan 01, 2009
SOURCE: Onkyo TX-SV919THX, No Output
I have found the battery location. It is roughly on the opposite side of the pc board where the display is. It basically faces the heat sinks. It's one of those small watch sized batteries and is soldered but sticking off the pc board with 2 leads. I could see that there was some leakage and corrosion. I still have to figure out what needs to be dis-assembled to get access to it so I can unsolder the bad battery and replace it. This stupid little battery seems to need replacing every 6-8 years! When it dies, it seems to disable the preamp section from passing any signal giving the symptoms that the amps are dead. However, if you try to use the pre-outs to an external amp, nothing. So, my guess is it has something to do with the preamp section. Anyway, that will be my weekend project to try to get at the battery and replace it with "longer leads" so it will be easier to replace in 6 years when it dies again. Great design Onkyo! You dumb-*** weasels!!!! I hate when companies engineer things to break so you are likely to pay them to fix it. Not this time, "No soup for you!"
Posted on Feb 19, 2009
Gurudristi
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
Wire diagram for surround sound
http://static.fixya.com/Manuals/O/Onkyo/TX_DS595_5_1_61851C3AAA3EA98913A226B1F1FDDAD1.pdf there is the manual for your unit
May 08, 2011 | Onkyo TX-DS595 Receiver
Onkyo TX-DS898 Memory Loss
THEY USE A MEMORY CAP.ITS LOCATED ON THE MAIN PCB ASSEMBLY, REF. C7701 ONKYO PART NUMBER IS 3000078/ WITH THE UNIT TURNED OFF MEASURE THE VOLTAGE YOU SHOULD HAVE APPROX 5V IF NOT THE CAP IS BAD. ALSO MEASURE WITH UNIT ON AND YOU SHOULD ALSO MEASURE 5 V IF NOT THEN THE SUPPLY VOLTAGE GOING TO THE CAP IS BAD.
Apr 18, 2010 | Onkyo TX-DS898 Receiver
The receiver thinks there are headphones connected
Onkyo directed me to return the unit to a service center. Apparently this is a known issue and after reading web postings I believe it. There were dozens of similar cases with a variety of Onkyo recievers. I was able to remove the ribon connector from the headphones and discovered it is not a shorted headphone detector. We will see what the service center does. I'm not looking forward to paying for shipping a 66 lb receiver.
Aug 04, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Feb 19, 2009 | Onkyo TX-SR502 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
Onkyo Forgets it's input settings during power outages
yes there is ,,, it is located on the same board that has 3 fuses on it, you will have to unplug the unit before disassembly, and remove the top cove and bottow covers,,,, you will have to de-solder a small battery pack surrounded by either blue or yellow heat shrink,,, please not the polarity before removal, as putting it in wrong will cause a non- memory retaining situation to continue...I hope this helps
Jul 07, 2007 | Onkyo TX-DS787 Receiver
Onkyo TX-SR502 Receiver Logo
435 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
