Question about Sanyo DVW-7200 DVD/VCR
Tape gets tangled in rca recorder
Both,when it rewinds or plays,the tape unravels
  • Sanyo Master
  • 458 Answers
Your take up spool or the pinch roller on the deck mechanism is probably not turning & causing the tape to spill into the deck. The cause of this could either be the motor is not turning the pinch roller if a belt has snapped or the clutch mechanism is not engaging the take up spool. If you remove the top cover & take a look at the tape when it is in play or rewind mode you will see if it spills on the right hand side, look to see in the right spool in the cassette tape is turning. The remedy would be to remove the deck mechanism & check the gears or belts.
Posted on Jul 26, 2009
    Problem Solver:
  • 6 Answers
VCR's are so cheep these days you can get another one that's cheeper then fixing a crappy RCA
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Nov 07, 2014 | Microwave Ovens
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
I tried to see the 8mm tape video (recorded 10 years ago- my wedding party) but I couldn,t see anything!! I wondering if the tape needs cleaning ? or that is the reason?
Sometimes that happens...just keep fast forwarding and rewinding and playing and it'll usually eventually sync up.
Once it does, record it onto some other media while it's still working.
Mar 02, 2011 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
How do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Jan 19, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Jun 10, 2007 | JVC Cybercam GR-DVL805 Mini DV Digital...
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
Televison & Video Logo
208 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
