Question about Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator
Icicles in my freezer; ice-maker motor is frozen! 2d time in 1 mo
I have a JS48SEDBA 48" Jenn-Air refrigerator. A month ago, I had the exact same problem with my ice-maker motor frozen because the water pan on top was not draining properly. I also had icicles in my freezer compartment from the water overflowing the drain pan and freezing around the motor of the ice-dispenser as well. A repair guy came to "fix" the problem, but the same problem has developed one month later; apparently, the drain was still clogged, or was unclogged but got clogged again. The icicles are back, and the ice-maker motor is frozen again.
  • aquinor Jul 27, 2009
    Rylee, you sent me a link with a diagram with numbers, but no description of what the parts are (looks like ice-maker parts), as well as an electrical diagram which means absolutely nothing to me. This has been of very little help to me.
    I noticed another customer had the same problem as mine. Do you know how that was resolved?
    Thanks!
    - Ruben Aquino
    p.s. your website's list of recommended repair services includes one in San Francisco, and one in Kansas City, Missouri (I live in Glendale, Ca, in LA county).... ???
  • 10,865 Answers
Hi. What a frustration. I am thinking as u are that the drain line was never properly and thouroughly cleaned and sanitized and that the mold or whatever has come back. Here is the best way to proceed:
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); There is a drain leading out of the freezer and another from the refrigerator. In top freezer models, the freezer may drain the water onto the back wall. It actually runs down the wall to the refrigerator floor drain. In other cases, there may be a drain tube leading out the freezer. The refrigerator drain is either located on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
In side-by-side models, the freezer and refrigerator will probably each have an outlet to the drain pan under the appliance.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
You can purchase this tubing at most hardware stores.
Posted on Jul 28, 2009
  • Joe Hogan Jul 28, 2009
    Get back and let me know how you make out.
    Brigadier General:
  • 8,619 Answers
Hi
This may have happened because of a clog in the drain pipe and/or due to the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. Also check the water valves wiring as given in this link. Please see these links for more details:
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 26, 2009
Inside the freezer has bunch of icicles and the freezer temperature fluctuate and it does not stay constant?
Your evaporator fan motor might be bad. This causes the icicles. Listen for the fan motor turning next time, you may want to hold down door switch.
Rich
Western Appliance Repair Boise id
Dec 02, 2010 | Jenn-Air Refrigerators
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Frozen water formed in the freezer
Your drain tube is plugged. The ice is formed in the bottom because when your freezer goes into a defrost cycle the tube is plugged so there is nowhere for the water to drain so it overflows and leaks into the bottom of the freezer. I know you have defrosted it but it takes longer to defrost the tube than just the ice on the bottom. You can call a service tech to take care of this or just unplug the refer. for 24 hours. This will fix your problem. I do this all the time and it always fixes it.
Feb 09, 2009 | Jenn-Air 48" Side-By-Side Built-In...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
117 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
