Question about Hayward EC-40 DE Pool Filter with pump
Replace the grids in my Pentair NSP60 filter
I need instructions on how to open the pentair filter and replace the grids
  • 990 Answers
Remove the band clamp on the tank and start the pump for a second or two untill the top pops then open the air bleed to drain the tank and pull top off. There will be two nuts that you remove from the long studs that come through the top manifold . Once you remove these gently turn the manifold back and forth while pulling up on it. When you get it off rock the grids and pull them up. You will need a garbage handy while you do this to put the caked D.E. in. When all the grids are out you acn pull the bottom frame out. and rinse the base by turning the pump on till the filter base fills then shut the pump off and open the backwash and rinse with a hose while it drains out. You can rinse the parts while you do this if your quick enough. If you used a five gallon bucket to put your old D.E. in Turn the manifold upside down and then assemble with your new grids. Seven are the same size one is smaller that one coresponds with the stand pipe and the bottom has a notch for the same. Whild upside down the grids will line up with the bottom frame a lot easer than when righted. with the steel bolts in their holes carefully tilt the assembly to start the nuts on the through bolts. When they are hand tight rite the assembly and finish tightening it all up. At this point you can lube the stand pipe "O" ring and install a new tank "O" ring. Set the assembly back in the tank and replace the top faceing the same direction as when it came off. Replace the tank band clamp and tighten evenly one side then the other if you have two bolts on it till the coils in the springs touch each other. If it's old enough not to have springs on the bolts tighten them till they squeek.Start pump, bleed air out of tank, ck for leaks and recharge the filter. If you take apart like this once a year and clean the grids or after alge problems you should get eight or ten years from the grids. Good luck!
Posted on Oct 05, 2009
What is DE
De is called diatomacious earth. It is a powder made to coat the grids of a de filter in order to trap small particles. Then you backwash the old de out, and replace with appropriate amount depending on your filter size. Backwashing only works for so long before you need to clean the grids and recharge them with fresh de.
May 30, 2016 | Pentair Prowler 720 Pool Cleaner
Need help to re-assemble grits on a Pentair fns 48 filter
start with the short one by where cut out is for pipe arrange then put back together see manual if you dont have manual check pentair site or send me more info ill try to help
Nov 02, 2013 | Pentair Fns Plus 48 sqft De Pool Filter...
Need to reassemble the grids in a pentair fns plus
short grid goes by stand pipe then work the rest around make sure to tighten the screw enough
Jun 12, 2012 | Pentair Pool & Spa
Fsn plus - 60 Pentair filter - when I vacumm DE is being circulated back into the pool
check for rips in grids if ok make sure rack tightened down correctly if voids DE will leak back into pool
Jan 17, 2012 | Pentair Pool & Spa
The filter was backwashed the filter and tnen set on filter adding the powder and the powed er started coming out the return line? what is wrong/ I would like to know how do you clean the filter it was...
You probably have holes in your grids and will need to replace them. You can find a manual at http://www.pentairpool.com/index.htm
Just follow the menu's to get to filters and manual's be sure to have your model number.
Sep 05, 2010 | Pentair Fns Plus 48 sqft De Pool Filter...
Pent air pool filter
Buddy is this happening, after the pump turns off or during.. Need more info.. type of filter.. Sometimes the sleeves on the neck area of the panel. Where it mates with the manifold slide down, you will have a small opening. Might be from their.. Could be a hole on one of the panels. Do you have a push/pull valve or a multiport valve (to back wash)
Mar 10, 2009 | Pentair "Pentair" In Ground Pool Pump ...
Hayward EC-40 DE Pool Filter  with pump Logo
689 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
