Health & Beauty Logo
Omar Shapsough Posted on Jul 01, 2017
A low pressure problem after high blood pressure.
Does stevia leaf cause high blood pressure
Hello, April -
The only information I have found regarding stevia and hypertension (high blood pressure) talks about using stevia as a sweetner while taking medication to lower blood pressure.
From: MedlinePlus, a database of medical and health information from the U.S. National Library of Medicine:
https://medlineplus.gov/druginfo/natural/682.html
[Quote]
Some research shows that stevia might decrease blood pressure. In theory, taking stevia along with medications used for lowering high blood pressure might cause your blood pressure to go too low. However, some research shows that stevia does not affect blood pressure. Therefore, it's not known if this potential interaction is a big concern.
[End quote]
Note: I am a librarian by profession.
Best wishes.
2answers
What is the meaning of blood pressure 235/100
Andrew is correct
you should be on the way to a hospital in an ambulance
unless you are one of thousands that have got a home blood pressure testing machine and do not know how to calibrate it or it is faulty in which case junk it and keep going for regular tests at the doctors , pharmacists or chemists
Why I get E-1 when I want to measure my blood pressure?
This is an error message from the blood pressure cuff. If u still have manual it will tell what this means. If not try rebooting it take batteries out or unplug straighten cord and flatten cuff. Now try again. If u have highe blood pressure it may be to high for this cuff to read, translation GET A DOCTORS APPT. or the same if low pressure, to low to measure again doctors appt. hope this helps. K
4helpful
4answers
What causes low blood pressure?
low blood pressure dangerous only if it causes
noticeable signs and symptoms, such as:
Dizziness or lightheadedness
Fainting (called syncope )
Dehydration and unusual thirst - Dehydration can sometimes
cause blood pressure to drop. However, dehydration does not
automatically signal low blood pressure. Fever, vomiting, severe
diarrhea, overuse of diuretics and strenuous exercise can all lead
to dehydration, a potentially serious condition in which your body
loses more water than you take in. Even mild dehydration ( a loss
of as little as 1 percent to 2 percent of body weight ), can cause
weakness, dizziness and fatigue.
Lack of concentration
Blurred vision
Nausea
Cold, clammy, pale skin
Rapid, shallow breathing
Fatigue
Depression
Low blood pressure can occur with:
Prolonged bed rest
Pregnancy - During the first 24 weeks of pregnancy, it's
common for blood pressure to drop.
Decreases in blood volume - A decrease in blood volume can
also cause blood pressure to drop. A significant loss of blood
from major trauma, dehydration or severe internal bleeding
reduces blood volume, leading to a severe drop in blood pressure.
Certain medications - A number of drugs can cause low blood
pressure, including diuretics and other drugs that treat
hypertension; heart medications such as beta blockers; drugs for
Parkinson's disease; tricyclic antidepressants; erectile dysfunction
drugs, particularly in combination with nitroglycerine; narcotics
and alcohol. Other prescription and over-the-counter drugs may
cause low blood pressure when taken in combination with HBP
medications.
Heart problems - Among the heart conditions that can lead to
low blood pressure are an abnormally low heart rate
(bradycardia ), problems with heart valves , heart attack and heart
failure . Your heart may not be able to circulate enough blood to
meet your body's needs.
Endocrine problems - Such problems include complications with
hormone-producing glands in the body's endocrine systems;
specifically, an under-active thyroid (hypothyroidism), parathyroid
disease, adrenal insufficiency (Addison's disease), low blood
sugar and, in some cases, diabetes.
Severe infection (septic shock) - Septic shock can occur when
bacteria leave the original site of an infection (most often in the
lungs, abdomen or ******* tract) and enter the bloodstream. The
bacteria then produce toxins that affect blood vessels, leading to
a profound and life-threatening decline in blood pressure.
Allergic reaction (anaphylaxis) - Anaphylactic shock is a
sometimes-fatal allergic reaction that can occur in people who are
highly sensitive to drugs such as penicillin, to certain foods such
as peanuts, or to bee or wasp stings. This type of shock is
characterized by breathing problems, hives, itching, a swollen
throat and a sudden, dramatic fall in blood pressure.
Neurally mediated hypotension - Unlike orthostatic
hypotension, this disorder causes blood pressure to drop after
standing for long periods, leading to symptoms such as dizziness,
nausea and fainting. This condition primarily affects young people
and occurs because of a miscommunication between the heart
and the brain.
Nutritional deficiencies - A lack of the essential vitamins B-12
and folic acid can cause anemia, which in turn can lead to low
blood pressure.
Severely low blood pressure can have underlying causes that may:
Be an indication of serious heart, endocrine or neurological
disorders
Deprive the brain and other vital organs of oxygen and
nutrients, ultimately leading to shock, which can be life
threatening
How to calibrate my Jobar blood pressure cuff?
Was yous at heart height when you took readings? Too low will give high readings. Nibp can differentiate by as much as 10-15% remember.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
