Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
Pressure falls to under 80psi before restart
I have a rand 4000
My power nailer requires minim of 90psi to run properly and the compressor allows the pressure to fall below 80psi before it restarts.
Scott
scottanna@comcast.net
    President:
  • 583 Answers
Thereshould be an adjustment inside the control box once you take the cover off it is self explanitory you can raise or lower the cutin cutout pressuresto suit your requirements
Posted on Jul 27, 2009
Evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Apr 08, 2012 | Craftsman Air Tools & Compressors
DRIVER DOES NOT RETURN ALL THE WAY TO THE TOP
What air pressure are you using? Anything under 80psi may not be enough to allow the piston to fully return. 90-110psi is the most common range to operate nailers and staplers. A bent driver can also be hanging up causing it not to return. This is most common on 18 (and some 16) gauge brad/finish nailers since they usually have a pretty thin driver blade.
Feb 22, 2012 | Air Tools & Compressors
My ingersoll rand garagemate's regulated pressure drops from 90psi to 70psi almost instantly after using air tools, even though tank pressure is above 100psi. What is going on here? I replaced the...
are you talking about the little regulator gauge droping while you use it, as it does.its all to do with how much psi can pass through the airline at once. ther for since air is leaving the regulator it drops but when u stop using it it should shoot up straight away, if it doesnt means your regulator needs ajusted.
Jun 25, 2010 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
When the air compresor turns on the first time it runs good when we torn it off and try to restar it, it will not turn on
the switch on most air compressors have a low start and stop rating most run at 90psi low and 120 to 130psi off depending on your unit. if you turn on your unit and if it humens, than check the pressure valve mounted on the tank at the end of your feed line. if no humming check your switch
Oct 14, 2009 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
No air to hose on air compressor
Check to make sure that the regulator is set to the proper setting. You need to turn the knob clockwise to increase pressure. This is opposite of a valve which you turn counterclockwise to open.
Post a comment so we know how you did.
Thanks,
Tim
May 27, 2009 | NRS Air Pro Air Hose 1/4 X 50' It's What...
BN125A Nailer will not fire even after rebuild kit
low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
May 27, 2009 | Porter Cable Cable Brad Nailer and...
Constantly releases 30psi of air into atmosphere before holding air in the tank
mine does the same damm thing , is it broke or can it be adjusted . It buggs the heck out of me.
Oct 23, 2008 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
148 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
