Question about Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 22.2 Cu. Ft. - PDS22MFS
GE profile Refridgerator Water tastes like mildew
It is horrible
  • tulipstar33 Jul 26, 2009
    Because mildew tastes horrible
    Sergeant:
  • 199 Answers
Why is it horrible
Posted on Jul 26, 2009
  • Carlos Solas
    Carlos Solas Jul 26, 2009
    replace filter and piping
GE refrigerator chilled water has mildew taste
change the water filter usually located in the upper right hand corner of the refrigerator compartment on side x sides,if top mount freezer it can be about anywhere inside the unit except freezer compartment
May 11, 2012 | GE Refrigerators
I have a GE Profile Model PSC23NGPA side by side refrigerator and recently the dispensed water tastes mildewed or something. I usually replace the filter and it corrects it. This time the filter didn't...
The bad taste in the water rarely comes from the refrigerator itself and 99% of the time comes from the water supply. If I had to guess, I would say that there is some kind of flexible line hooking your fridge up to the house. Either braided stainless steel or an opaque whitish rubber line and that will be the culprit. (attached pic shows both types)
They are usually used because they bend easily and are very abrasion resistant however I have found over the years that something within the rubber lining makes the water taste horrible! It does not happen right away and I have seen it occur between 8 months to several years after initial install date.
If you have this type then have it replaced with copper line only with precautions to avoid damage when moving the unit in or out. Install the filter bypass and flush it for several days by letting the icemaker run normally while dumping the bucket and getting glasses of water with at least a minute or two break in between so you do not overheat the water valve.
Let us know if this helps/corrects the issue
Feb 03, 2018 | GE Profile PSS26NGS Side by Side...
Water taste and smells like mildew
Hi and welcome to FixYa. I am Kelly.
How about the house tap water same odor and taste or just the fridge?
If it is just the Fridge I am assuming your unit has been around for a while.
If you have a mildew build up in the plastic tubing of your ref it can be a tedious cleaning procedure to get it all out of the system The stuff ends up sticking to all of the plastic tubing inside the unit and is so hard to get rid of. What you can do is have all of the plastic lines changed out in the Refridgerator from the water valve outlet to the the water in door and icemaker. It is just time consuming to do it.
Water supply to unit off for the steps below.
You can try using a small baster (I use a hair dye applicator bottle) and a bleached water mix that is not too strong. I would recommend that you start AFTER the water valve in the bottom of the unit. You have got to be able to introdue enough pressure through the system so that when the water in door switch is activate that the bleached mixture will flow out of the spout. You will have to introduce the water until you can smell it in the water you get from the glass you used to catch the water. Then let it stand for an hour. Re-intorduce the same amount of bleached water as before and wait another hour. After the second mixed water bleaching reconnect the water supply and purge it at the water in door outlet with a glass.
Probably sounds a bit much but this is from experience and believe me it does take lots of time.
I am sure this is not what you were expecting but it really is the only way your going to rid yourself of the bad smelling and tasting water CURSE.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Pds GE Profile Bottom-Freezer Drawer...
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Terrible Plastic After-Tast in Dispensed Water (Refrig)
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Jul 14, 2009 | Refrigerators
Musty smell/taste from water dispenser in refridgerator
The icemaker has mold or mildew in the little nooks and crannies. An appliance parts supplier might have something available for flushing but I am not sure. There might be something in the ice bin or on the auger contaminating the ice and water as well. Check back to the source as the water supply filter may have accumulated something unpleasant while the ice maker was down. Hope this input helps.
Dec 30, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water and Ice have a horrible taste.
Thats becouse the instaler use cooper line, in a short period will taste beter and beter, but I don use cooper becouse that I use rubber or plastic make it change and let the water run for a waile...good luck and rate me...
Jan 20, 2008 | GE GSH25JFR Side by Side Refrigerator
Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 22.2 Cu. Ft. - PDS22MFS Logo
243 people viewed this question
Top Pds Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
LARRY BARAN
LARRY BARAN
Level 1 Expert
Are you a Pds Refrigerator Expert? Answer questions, earn points and help others
