Question about EliteGroup P4VMM2 Motherboard
Motherboard problem i have probem w/ my board. i already change power supply but still no power. can you help my problem?
  • osmonde Nov 30, 2007
    same exact problem
I have probem with my board. i already change power supply but still no power. can you help my problem?
Posted on Dec 12, 2007
  • 482 Answers
The mother board is bad. there is only two things that keep it from running. the power box or the monther board. most of the time it's both.
Posted on Dec 03, 2007
I have a D865GLC board - when I try to power it up, nothing happens. The power supply's fan also does not run. I tried replacing pwr supply, no change. I was wondering if the P4 chip went, or if it's the...
the problem is with the power supply .. try to handle it by someone expert you may damage the board and power supply if the board is not for the right power supply ,moreover there are jumper settings also .so be careful to play with power... my suggestion is that you take both to a
do vote if it helps
Apr 02, 2011 | Intel D865GBF Motherboard
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
Feb 11, 2011 | Dell (002TR) Motherboard
I put a new power supply in and my screen says ntldr is missing why?
test the leads that attach from your motherboard to your hard drive or replace them there probably old and faulty
make sure that you have secure connections to all drives cd/dvd 3.1/2 inch floppy and hour hard drive one bad/faulty lead can lead to lots of probems ntldr is the software that helps your operating system load
Oct 31, 2010 | Compaq 220W Power Supply for PDP-121P...
Motherboard is not powering on and generates heat from the power supply
Sounds like a faulty power supply... Time to replace it! :)
Also, read this tip of mine to find out more possible causes to your probem.
Jun 28, 2010 | Foxconn K7S741GXMG-6L Motherboard
Board would not turn on
Well, then it could be one of 3 things, it could still be the power supply that's at fault. If you have a PSU tester, check the voltage on each rail and see if it's coming in properly (if you don't have a tester, bring the unit to an authorized service center to have it tested). The second option, would of course be the motherboard may have failed or is defective. Make sure that when you connect the ATX power supply to the board, remove all the RAM, hard drives, optical drives and expansion cards from your PCI, PCI-E, AGP, ISA, or whathaveyou and try with just the board and the power. If it's still a no go, then board or possibly processor may be shot.
Last option, and this one is the sillier of the three, also make sure that you have the jumper pin for the front panel power button connected to its respective spot on the motherboard itself. I know it may sound silly, but I have to say it, as a technical expert, because, well, you never know.
May 14, 2009 | Computers & Internet
I have a emachine PC. PowerSupply blew up. changed it still down
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
No video
Go to the Asus website and download the drivers for this board. It's most likely that it did not come with drivers installed. Hopefully this will fix the problem. Good luck.
Dec 23, 2008 | ASUS P4V8X-MX Motherboard
Doesnt start anymore
ok a couple things this sounds like
1 the dual power button on back of power supply needs to be triped
2 the power supply took a dump on you need to replace power supply
if your motherboard had crashed you would have had a meltdown in tower and you would have smelled it like burnt plastic
sometimes comps require a beefier power supply and most basic comps come with twiggy kind of power supplys
depends on how many toys you have in your system and how long its being ran
May 28, 2008 | Intel Desktop Board D845WN Motherboard
Booting problem
the blinking led on the keyboard suggests some probems with the power supply ...
Do u hear any beeps from the comp ?
U can try to disasamble everything and reasamble them... also see that u have a propper isolation between the motherboard and the case. And if u can messure the power supply;'s parrameters
Mar 10, 2008 | Intel D915GAG Socket 775 Motherboard -...
Mobo no boot after changed power supply
I couldn?t find much on the motherboard either. Over the years I have only seen a handful of boards with fuses so I doubt you have on your board. -Double check the new power supply and ensure it is designed for your motherboard. -Double check the power supply connections to the motherboard, the connectors should mate up exactly to the motherboard. -If you did remove anything double check for shorts, grounding and so on. Any of those can cause the same symptoms. -Test the case power switch, it could be bad. -Some power supplies have on/off rocker switches on them (in the rear by the A/C power socket), make sure it?s on. -Most power supplies have a 115/225 volt switch in the rear by the A/C power socket; make sure it is set to whatever is appropriate for your country. I assume you use 115V like we do down here. -Make sure the A/C power cord is working. -Test the power supply in another computer or if not available you can generally pickup an inexpensive tester for $10 to $15 at a computer store that sells parts. -If you get this far and still have no solution then my guess would be the old power supply had a power surge on its way out and damaged something major on the motherboard. You can look on the motherboard for obvious signs of damage; however, unless you know what you are doing I don?t recommend the typical user try to perform repairs of this sort. Let us know how things go or if we can help further.
Jan 01, 2007 | Foxconn K7S741GXMG-6L Motherboard
EliteGroup P4VMM2 Motherboard Logo
46 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
