Question about Al Agnew Al Ag 3 Piece Pocket Watch Collection
2003 deer pocket watch Al Agnew is it wind up or Battery
  • Anonymous Mar 27, 2014
    with deer pictures on it
  • 65 Answers
Often with battery powered watches the word "Quartz" will be written on the dial. In the abscent of that you can look at the mechanism inside (typically by removing the case back).
Alternately (this may not be an absolute confirmation) with the winder in neutral position i.e. pressed all the way in, turn the crown (winding button) and if it spins freely it's probably quartz. Because unless it's broken most mechanical watches click as the watch is
wound up (except some automatics which cant be crown wound).
Plus if it's working and left unworn for a few days yet continues to run it's probably quartz.
Please rate this solution.
Posted on Jul 27, 2009
  • caplib109 Jul 27, 2009
    Often with battery powered watches the word "Quartz" will be written on the dial. In the abscent of that you can look at the mechanism inside (typically by removing the case back). Alternately (this may not be an absolute confirmation) with the winder in neutral position i.e. pressed all the way
    in, turn the crown (winding button) and if it spins freely it's probably quartz. Because unless it's broken most mechanical watches click as the watch is wound up (except some automatics which cant be crown wound). Plus if it's working and left unworn for a few days yet continues to run it's probably quartz. Please rate my solution. Thanks.
I have a remington pocket watch from my great great grandfather and I don't know what battery it takes please help.
If its that old, it may not use a battery. Older watches usually use a wind up knob. Yours is on top, try winding it clockwise. You should hear some clicks if its working. good luck!
May 03, 2017 | Pocket Watch Watches
Do new James Michael pocket watches come with a battery?
Yes, if it is of the battery type
Movement Type
The movement, or inner workings, of a watch are what make up the main timekeeping mechanism. This mechanism measures the passage of time and displays the current time and other information including date, day and month. These movements can be entirely mechanical, entirely electronic or a combination of the two.
Mechanical movements, such as hand wound or automatic watches require winding in order to run. An automatic watch uses the force of gravity to constantly wind itself. Automatic watches have a greater consistency of power and therefore can be more accurate.
An electronic watch employs the use of a tiny quartz crystal that vibrates in the presence of electricity. This type of watch is powered by a battery and their time is regulated by the tiny quartz crystal. This is why most electronic watches are also called quartz watches. Solar powered watches convert energy from light into electricity which is then stored in a rechargeable battery. These watches do not need to have the battery replaced as long as they are regularly exposed to a fairly strong light source.
Kinetic powered watches use a combination of mechanical and electronic elements. Usually a weight rotates with the motion of the wearer?s arm which turns a generator to supply power. It is similar to an automatic watch except that electrical power is generated by the mechanical motion.
Men James Michael Pocket Watch
Jun 19, 2016 | Pocket Watches Watches
How to do you open the case to change the battery?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 02, 2010 | Al Agnew Al Ag 3 Piece Pocket Watch...
Watch is fully wind up but doesn't run?
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Dec 29, 2009 | Sterling J3E Hamilton Antique Pocket Watch
How do I open a medana pocket watch?
First -let's check out what type of watch you have. If you push the crown in and it turns freely back and forth with no resistance at all - this is battery driven watch.
If you do the same and feel and hear some clicking and resistance- this is mechanical (spring driven) watch.
Next - the case: Usually all pocket watches have snap-on casebacks. Take an eyeglass and examine the case. Even if you think there is no any grooves or gaps- try to pry it using watchmakers caseback opener (about $5 on ebay).
In case if there are no chance to open caseback - that means you have one of the cases assemblad watch glass fitted last and that means you have to take glass out first and then only to get to the movement.
As you will not be able to get the glass out without braking it, the only solution will be to visit your nearest watchmakers shop and ask for help.
Rate, please.
Jul 22, 2009 | Avalon Medana Gold-Tone Open Face Railroad...
My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still...
it has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
Jul 12, 2009 | Fossil VT2657 Pocket Watch
Watch hands move freely inside as watch turns
It's a wind up...and please don't open the case yourself.  Take it for repair.
Mar 22, 2009 | Watches
Watches Logo
396 people viewed this question
Top Al Agnew Watches Experts
Jimmy Accardi
Are you an Al Agnew Watch Expert? Answer questions, earn points and help others
