Question about Pioneer CDJ-700S Turntable
Info cdj700s cannot open error 9101 can i help me to trouble?
  • 515 Answers
Error 9101 is a read/tray error. More than likely your reader/pick up tray is faulty, and will need to be replaced. For the CDJ700, cost for a new pick up assembly is about $75 - and not an easy fix. Lots of stuff to remove first. Kinda like a car. To get to 1 section, you have to remove 3 others.
Hope this helps.
- TWEAK A/V LAB
Posted on Nov 22, 2007
Shuang Ma Double Horse 9101 RC Helicopter English Instruction Manual Please give me a link to download the manual. Appreciated!!!
Hello, my 9101 double horse turn great in one direction but very slow in the other. Any Ideas as to what might be the problem and the fix? Any help would be most appreciated. Thanks in advance for your help. Most Sincerely, WM
Aug 26, 2011 | Toys
Eror 9101
this error is for Mechanical time out. Disc inserted cant be read in given time. There may be dust or other particles in compartment of CDJ. Please make sure if you can open it yourself and clean the compartment.
Thx,
djajay
Aug 04, 2010 | Pioneer CDJ-200 CD Player
Wwhy 9101 in display? i am brasilian.
hi 9101 is mechanical time out error. When u insert disc to ur CDJ
and that is not able to read disc within the given time then
error 9101 display.
Please try to clean laser and compartment of your CDJ, their may be dirt, dust inside it. I hope this will help.
thx
djajay
May 25, 2010 | Pioneer CDJ-100 Turntable
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
PIONEER CDJ 400 E-9101
E-9101 error is mechanical time out. You need to clean compartment to your player, dirt or dust may be there into insertion compartment to the CDJ
djajay
May 13, 2010 | Pioneer CDJ-700S Turntable
What is Error 9101, on the pioneer MK2 800. and how can it be solve
Error 9101 is a Disk-Read error. More than likely either your traverse assembly, or your loading motor is damaged - or both.
In either case, you'll have to take it to a qualified service center for repair.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 10, 2009 | Pioneer CDJ-800MK2 Turntable
What does error code E-9101 mean?
According to the 700s/500s service manual:
E-9101 - MECHANICAL TIME OUT - Mechanical operation did not end in allotted time (CLAMP: 4s) - The loading mechanism is defective.
It means that, for some reason, the mechanism that moves the optical assembly couldn't move to the right position in the limit time of 4 seconds. If there's no CD inside, from the tranparent ring probaly you'll see that the sliding door inside the unit has remained improperly closed (the laser pickup couldn't "see" anything).
Unscrew the 4 black screws under your unit, and remove the cover. If the optical unit has remained exposed (probably not), be careful to not touch the lens. On the left part there's a smal motor and gear mechanism. Try to manually rotate the gears, see how the mechanism works (sliding door opens, optical pickup become exposed and goes up) and check if there's any strange behavior (hard to move, strange clicking noises). Also check for excess dirt over moving parts and gears in the whole unit. To clean it, unscrew the 4 black screws that hold all this unit, remove it, clean it with some soft brush and cloth (avoid using air pressure, also avoid breath blowing anything). Replace the grease with some plastic-safe grease and remount everything.
If nothing of this helps, maybe your sliding motor has some problem. In this case, only an repair shop could help.
Best Regards Fernando
Jul 24, 2009 | Pioneer CDJ-700S Turntable
Pionner CDJ700S Lens, DWY1069 replace the DWY1067?
Hi Marcelo. I´m from Brazil, same CDJ-700s, same problem as yours. From what I´ve researched until now, DWY 1067 an DWY1069 ARE NOT FULLY INTERCHANGABLE on CDJ-700s and maybe 500s. I think some newer 700s already came out with 1069 from factory, so this is why all this misunterstanding. On older 700s that came out with 1067, some SMD components must be changed in the mainboard in order to 1069 work properly. Mine came ou with 1067, I´ve replaced it with a 1069, didn´t worked well (sound skipped, or didn´t play at all).
In 2001 Pioneer released a replacement kit for this situation. The kit is named GXX1200, and includes the optical unit (DWY1069) which is included in the whole mechanical unit (DXXsomething, depends on model), and SMD resistors and capacitors for replacement. Dirty job, I know...
Since I already bought the replacement 1069´s, I´ll buy the SMD components too. I´ll let you know if will this work. Not an easy task, but I´ll try.
Here you can check the whole kit:
http://www.chsinteractive.co.uk/electrical-components/general-components/lasers-optical-heads-ribbons-and-motors/laser-optical-heads-assemblys-original/pioneer/dxm1239a-gxx1200-laser-optical-head-assembly-replacement-kit-pioneer.htm
And here the documentation for the replacement:
http://www.chsinteractive.co.uk/pdf_data/24001LM.pdf
Regards
Fernando Seiji Imay
Apr 16, 2009 | Pioneer CDJ-700S Turntable
Cdj 700
hi
error E-9101 is notifying that there is dust in the system
get the drives professionally cleaned and reset the units
D
Nov 20, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-700S Turntable Logo
159 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
