Question about Microwave Ovens
Microwave will heat v.slightly but will not cook
Microwave has always worked fine. Bought it new in Jan 2008. Went to heat some milk up the other day and it was very lukewarm and wouldn't go any hotter. User manual is useless - any tips please?!?!? Can't find product in website list but it is a Kenwood KEN ST/AL25 Microwave.
  • 199 Answers
Make sure that the power level is on high. I'm guessing you already checked that. There is a malfunction in the microprocessor, the firmware in the EPROM, The Litz Coil (high voltage high frequency) or a bad Magnetron tube. Either way, unless it is a super high end MW, it is not worth repairing unless you can do it your self. If you have a volt meter I can go through some basic troubleshooting with you when you repost. This is high voltage stuff so be careful, eye protection, rubber gloves, no jewelry.
Posted on Jul 26, 2009
When the problem first started i'd punch in the cook time, the only way the microwave would run and heat is if i held up on the outside of the door. Two days later it just quit working all togethe
Call Lowe's to see if the warranty has run out. If still good, take it back. If not, call the manufacturer of the unit and see what the problem is. Sounds like the door support or hinge has weakened and the unit will not operate with the door slightly ajar. Unplug the unit for safety's sake until you find out what is wrong.
Feb 14, 2013 | GE JES1142SJ Microwave Oven
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
My LG over the range microwave doesn't heat any more
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
That said, you can get free estimates on the cost of a repair but you should also consider a replacement which may be a better option for you.
What they do not tell you about over the stove microwaves is that they are constantly deteriorating due to the steam, oil, and other cooking fumes from the stove below. As a result, their life expectancy is definitely diminished.
Aug 19, 2009 | Microwave Ovens
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave will not cook
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 27, 2008 | GE JE2160 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
145 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
