Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Krups XP2010..No water flow
I got this a couple of months ago, and tried to use the espresso maker tonight for the first time. I filled the water tank, made sure it was pressed down firmly, and attached the empty filters for the first run through as instructed in the booklet. The machine is rather loud, and no water ever came out. I even tried using the frothing nozzle, but nothing came out of there either. Any ideas what's wrong? The coffee side of the machine works fine.
Same Problem
Feb 11, 2008
-   I have a 4020 and have a similiar problem, water flows without ground coffee, but once coffee is tapped to the filter, it can't make coffee..-
Jeff_HK Dec 12, 2007
-   You have to push down the water basket in the back, unless you press it down it will not work. I bought one of these machines and I am working on my third replacement in less than a year. Krups has possibly the worst brand on the market. Lots of room for improvement. Yours will break in a month or two so you should probably return it now. FYI - their customer service is 100% automated. Don't expect to speak with someone. -Tim-   Guest Dec 02, 2007
-   I have exactly the same problem with my Krups 936, which I was given 2nd hand. I am wondering if it is a problem with limescale.-   Guest
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
the portafilter basket leaks out the sides no matter how firmly held in place or the quantity of...
(More)
the portafilter basket leaks out the sides no matter how firmly held in place or the quantity of coffee in the basket
How do I remove the steam knob from my saeco vienna expresso maker. We have to fix it
my bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot...
(More)
my bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot for up to five minutes to heat it up. This still doesnt help.
