An installation wizard is part of a software installation or setup. It is called a wizard because it will take care of "complicated" or "sophisticated" parts of the installation for you with just the minimum amount of information provided by you. It does all of this without showing you all the details of the process, so the whole installation or setup will appear to work like magic.
Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
Plug the USB connector at the end of the LifeCam VX-1000 connection cable into an available USB port on your computer when prompted.
Place the LifeCam VX-1000 on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
Click the "Start" button, then click "All Programs" on the Start menu.
Click the "Microsoft LifeCam" folder icon in the list of programs on the Start menu, then click the "LifeCam" icon. That opens the LifeCam VX 1000 software and completes the installation process.
