Question about Mitsubishi VS-5043 50" Rear Projection Television
What is the chemical in a rear projection tv
I have a kp57hw40 sony rear projection tv. it looks like someone played with the back of it and it leaked some kind of chemical. what is it and how do i refile the light so that the tv works?
  • 1 more comment
  • djjackson23 Jul 27, 2009
    is the tv no good now. the tv turns on then turns off by itself then the stand by light blinks four times over and over. do you know what i could do to fix this?
  • djjackson23 Jul 29, 2009
    you helped me with the kp57hw40 coolant. thank you very much for the help. I have another problem though i fixed that problem and had it running last night the picture is off though. the picture starts about 6" above the bottom of the screen and its still has a little color setting i have to do but when i was playing with it my blue light flickered a little and shut off now it wont turn on. I dont have money to buy a new one or have it repaired what do you think i could do to fix it? thank you so much!
    David
    you can email me at djjackson2308@gmail.com but i will keep checking this for your answer thanks again.
    well i tried to change that but that was a no go i got it to work for about 30 min but i couldn't figure out how to get the bottom of the screen to move down to fit the screen and then it shut off again and gave me 7 blinks. do you think there is anyway to fix this without buying any parts? if you think of anything could you talk me through what i am doing. thanks
  • Mitsubishi Master
  • 8,617 Answers
The CRTs contain coolant which is most likely what leaked as thats the only liguid inside the television.
Posted on Jul 27, 2009
  • Sonny Berry
    Sonny Berry Jul 27, 2009
    the 4 blink error is for vertical failure. Which means the coolant may have dripped onto the A Board ( Green board on the right side looking in the rear) near IC8003 which is the vertical. The recomended repair id to thoroughly clean the area wherever the coolant leaked, then let dry. I use denatured alcohol first then a warm damp cloth, then I also resolder all components that were affected by the coolant as the coolant will destroy the solder. If the spill was there long enough you may need to replace the A board. If I can assist you further please let me know.
  • Sonny Berry
    Sonny Berry Jul 29, 2009
    If you were adjusting the Blue drive control it may just be turned down to low to light the tube. Try turning up the blue drive control (screen) just a little the tube should then light again.
Whats the g board look like inside the tv sony m.n.kp57ws520
These usuall have the big Capacitors on it and several Transformers on it. The board is not huge. check the link out, http://cgi.ebay.com/SONY-KP57HW40-A-1316-566-A-G-BOARD-/270676319280?pt=LH_DefaultDomain_0&hash=item3f0590dc30
Dec 26, 2010 | Sony KP-57WS520 57" Rear Projection...
Sony 52in. Rear Projection kp57hw40
Yeah, it can be fixed. Let me know when Tv goes to Off, how many times its Standby light blinks?
Aug 02, 2008 | Sony KP-57HW40 57" Rear Projection...
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
On stnandbymode never start SONY KP57HW40
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony projection tv
Sorry to be the bearer of bad news but I have the same model Sony with the same problem it was just returned from the repair shop (not to mention a $95.00 diagnosis charge) I was told that it will cost $700 to repair. The bulb in the back is gone and Sony no longer makes it so it would have to be re-built from scratch. I'm done.....
Aug 12, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
SONY KP57HW40 TV
Bad green CRT = common problem..........................T.
Oct 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
